It is currently Wed Oct 18, 2017 5:19 am
PostPosted: Thu Sep 22, 2016 5:51 am
So, let's say I'm cheap and want to use the same rear wheel for both a 10-speed bike and a different, 11-speed bike. Is this simply a matter of swapping cassettes on the freehub (including whatever spacer might be required)?
The reason I ask is that I don't yet want to go to the expense of upgrading the SRAM Red 2012 on my current road bike to Red 22, but the next bike I purchase is certain to come standard with an 11-speed drivetrain. I'd like to buy just one set of carbon racing tubular wheels for both bikes, eventually.
PostPosted: Thu Sep 22, 2016 6:42 am
Yeah, if you use 10 speed you need a spacer on the freehub, and that should be it. Many wheels come with the spacer included!
PostPosted: Thu Sep 22, 2016 7:19 am
Excellent, sounds like a plan!
My current wheels are Mavic Ksyrium, with a 10-speed SRAM cassette. Any foreseeable issues with putting an 11-speed Shimano cassette on them? I'm guessing the current freehub has a spacer already; perhaps I should remove it to see what spacer is on there.
PostPosted: Thu Sep 22, 2016 8:23 am
I've read that Mavic 10-speed wheels (older models) are already compatible with 11 speed, apparently you just have to remove a spacer and add a thinner one, from 3mm to 1.2mm (or just remove it), so it shouldn't be a problem.
PostPosted: Thu Sep 22, 2016 8:26 am
Simple as a cassette swap. My TT bike is still 10 speed, so when switching between bikes on the trainer just need to change the cassettes.
As for Mavic wheels they seemingly were ahead of the curve and most wheels I've encountered are 11 speed compatible. All you need to do is remove the included spacer and your 11 speed cassette will fit perfectly. It's been a while since I've used a mavic wheel, so someone with a current set will be able to confirm.
bike | instagram | strava
PostPosted: Thu Sep 22, 2016 4:16 pm
Yes, just remove the spacer when going from the 10spd to the 11spd for the Mavic wheels.
PostPosted: Thu Sep 22, 2016 8:56 pm
Awesome, thanks for the help everyone!
:beerchug:
PostPosted: Fri Sep 23, 2016 7:37 pm
not all 10-speed hubs are 11 speed capable. older wheels have a spacer...but for the Shimano splines...the spacer was for the transition of 9-speed to 10-speed.
if you have an older 10-speed hub with spacer removed...there's a few options. you can use an Edco 11-speed cassette, but have to buy an extra red lock ring especially for this purpose.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
There are no new unread posts for this topic. Consider this switching to Tubeless
3Pio
12
1770
Tue Jan 10, 2017 1:31 am
Fixie82 View the latest post
There are no new unread posts for this topic. Thoughts on switching frames?
baldwintodd
Mon May 08, 2017 4:46 pm
kulivontot View the latest post
There are no new unread posts for this topic. Considering switching to Campagnolo: A bunch of questions!
Lightweenie
30
2426
Mon Aug 07, 2017 3:42 pm
duvivr6 View the latest post
There are no new unread posts for this topic. Switching quarq powermeter between specialized cranksets
Louie
Sun Nov 06, 2016 2:04 pm
topflightpro View the latest post
There are no new unread posts for this topic. Compatibility Question - 11 speed Crankset & 9 Speed running gear
pfnsht
13
452
Fri Aug 25, 2017 2:31 pm
goodboyr View the latest post
Users browsing this forum: AJS914, barn, Chris3g, GMF and 24 guests
