Hey guys.
Do any of you know of a seatpost clamp that has the same gold color as the chris king bottom brackets/headsets? Would be nice to match my seatpost clamp with the rest of the bike.
Hope you can help
Chris King Gold Color - Seatpost Clamp?
Check out Fairwheelbikes.
Salsa, Hope, XLC, Loaded, and J&L makes that color. Just be careful you don't buy one that uses an alloy (aluminum) bolt and sleeve insert that the bolt goes into, get steel bolt and sleeve, sure it may weigh about 4 grams more but it won't break if you tighten it bit too much.
