Weight of Cannondale carbon Save seatpost?
dereksmalls
by dereksmalls
Does anyone know the total weight of the carbon Save seatpost that comes on the Evo Hi Mods including the cradle, bolts and yokes?
fa63
by fa63
According to this post:
viewtopic.php?f=10&t=141147
A 50 mm trimmed version weighs 162 g. Carbon headset spacers weigh about 0.5 g/mm, so the total weight should be around 187 g. This should be a good ballpark estimate in case you can't get an actual measurement.
dereksmalls
by dereksmalls
Cool thanks for finding that - I should have searched really. That's quite a hefty weight really. I've got a new Hi Mod on order and looking at what comes on it and what I can modify/replace to get the totla weight down and the seatpost is one such area. However, there aren't many people making after market setposts inthe 25.4mm diameter in carbon
dudemanppl
by dudemanppl
190.9g
cooper
by cooper
fa63 wrote:According to this post:
That's my seatpost, so I'll comment. Your pretty close actually.
Uncut my 25.4mm carbon SAVE seatpost was 196 grams. This includes a ~50mm long aluminum insert in the bottom of the seatpost for a Di2 battery installation. When I cut my seatpost down by 50mm the weight dropped to 162 grams.
nonamed
by nonamed
The total length was 350mm or 300mm ? Cause Cannondale Save Carbon seatpost is available in two heights.
cooper
by cooper
nonamed wrote:The total length was 350mm or 300mm ? Cause Cannondale Save Carbon seatpost is available in two heights.
original length was 300mm. Now 250mm.
evan326
by evan326
I'm about to try out one of these Hylix carbon posts for my caad 12. They seem to have pretty good reviews on here and across google. Their handlebars seem to be a bit more iffy but I'm thinking about it too.
snowdevlin
by snowdevlin
Has anyone tried replacing the bolts and cradle?
That should save a bit of weight, no?
Tristan
by Tristan
I assume this is to upgrade from the non-Save seatpost? My non-Save was 254g in 330mm length including the aluminium DI2 battery holder sleeve.
Wheelworks.co.nz
New Zealand handbuilt wheels
Ronaldevo
by Ronaldevo
25,4 mm at 350 mm is 196g here
Cleaner
by Cleaner
25.4 diameter 350 mm length is 199 grams.
