SRAM hidden bolt design... any issues I should know of?
PartRobot
by PartRobot
Hi,
I'm looking at getting a SRAM crankset and I was curious about the hidden bolt design; it looks awesome and they claim stiffness improvements. Since Praxis now support this design and it appears to be SRAM's approach-of-choice going forward, getting chainrings won't be a problem... but have you experienced any not-obvious-at first issues I should be aware of when making my decision?
Thanks!
Mr.Gib
by Mr.Gib
Sram Red Exogram cranks are excellent. No issues. Shifting is also very good. I wouldn't bother with Praxis rings. (No experience with Force or Rival cranks though.)
Valbrona
by Valbrona
If you use regular chainrings with hidden bolt you just have to rotate them 180 degrees to get the right timing. But this can place the catch pin in the wrong location.
F45
by F45
I got the standard Praxis (pre hidden bolt compatible) rings to fit with a little dremel action on the BB30 version.
PartRobot
by PartRobot
That's very helpful, thanks.
I'll probably be getting the new-generation SRAM chainrings with it (the sexy matte black ones) so I think everything should be fine then. Onwards with the Red!
Valbrona
by Valbrona
PartRobot
by PartRobot
Valbrona wrote:http://weightweenies.starbike.com/forum/viewtopic.php?f=3&t=141163
Wow. I hope that doesn't happen to me! Is it "common"?
mattr
by mattr
Only thing i'd be aware of is ring thickness.
Rings that aren't the same thickness as the OE rings will need a spacer. Rings that are thicker may well not fit at all.
Marin
by Marin
No.
PartRobot
by PartRobot
So in conclusion, then, specifically the use of the hidden versus non-hidden bolt shouldn't worry me?
