You don't need to use an 11-speed chain.
The inner width is the same as 10-speed, so the chainring doesn't know the difference.
I haven't tried running an 11-speed chain on an otherwise 10-speed drivetrain, but intuitively I believe it should run a little quieter, since there is fractionally less chance of chain rub on adjoining sprockets, and less chance at the FD.
11 Speed crank with 10 speed?
- bikerjulio
There's sometimes a buggy.
One.
One.
I've run 11 speed Campag chains on otherwise 10 speed set-ups
It works fine. Can't say I find it much quieter but certainly isn't noisier. About the same
One difference I find is that it is slightly more picky about wear on cassettes than a 10S chain. That might be real or imagined to be honest as you'll appreciate there are a lot of variables going on
I've also used 11 speed crank on otherwise 10S drivetrains including chain, and again, works fine. Can't notice any difference in operation here
i had a velo(folding mini bike) a while back and ran a 11 speed DA(Crank, FD) on a 10 speed cassette & RD cos the 11 speed shifters (for flat bar) were not avail back then. I used a 10 speed chain without any issue except noticed some scratches on the back of the large chain ring. I suspect maybe the 10 speed chain is thicker and caused the scratches during shifting between large and small chain ring.
Got a Rival 22 chainset on my CX bike with otherwise 10-speed components. Works well enough, but only about 400km on the rig so far. Lots of front shifting though, compared to a road bike around where I live (big ring all day every day).
Sent from mTalk
Sent from mTalk
