Bottom Bracket Inquiries
PrettyA
by PrettyA
Hey guys, I have a Giant TCR Adv 2013 and it uses the standard shimano bottom bracket, I recently bought a rotor inpower 3D30 and I have no idea which bottom bracket I should get, any idea guys?
sungod
by sungod
this chart should help you see which matches your frame and the crankset...
http://rotorbike.com/media/files/2012/1 ... 521655.pdf
Fixie82
by Fixie82
Giant use a BB86 shell which will require 41mm OD pressfit bearings with a 30mm ID. A search for 4130 bearings will produce a few results with Rotor 4130 being the most prevalent with either steel or ceramic bearings. I've found the Rotor bearings to be a little 'sticky' and not as smooth as other offerings. Currently I am using Hope 4130 bearings which are slightly more expensive but not as expensive as ceramic options. Kogel and Aican are ceramic options if you wanted a very high end BB.
I would recommend installing using Loctite such as 609 just to ensure a creak free ride.
ms6073
by ms6073
I can recommend the Hsc BB86/386 Ceramic Adapter Bottom Bracket which I used to install a SRM K-Force 386 EVO on a KTM Revelator Sky. I was going to use the FSA BB86/386EVO bottom bracket but it features an alluminum sleeve to join the two bearing cups which does not work on my frame due to a molded 'hump for the internal cable run on the bottom of the bottom bracket shell that required modification of the plastic sleeve that comes with the HSC bottom bracket.
- Michael
reknop
by reknop
Fixie82 wrote:Giant use a BB86 shell which will require 41mm OD pressfit bearings with a 30mm ID. A search for 4130 bearings will produce a few results with Rotor 4130 being the most prevalent with either steel or ceramic bearings. I've found the Rotor bearings to be a little 'sticky' and not as smooth as other offerings. Currently I am using Hope 4130 bearings which are slightly more expensive but not as expensive as ceramic options. Kogel and Aican are ceramic options if you wanted a very high end BB.
https://www.c-bear.com/bbchart.pdf
https://www.cycling-review.net
lewolive
by lewolive
The 41/30 bearings are what you need.
According to my experience, it has never been necessary to glue the following bearings: Rotor 41/30 gold ceramic, Cyclingceramic 41/30.
I also used the Rotor 41/30 steel and when it started to creak, it was because of the rust that appeared.
Leaving enough grease, cleaning regularly is a good solution to give extra life to these 41/30 bearings. You have chance, Inpower crank is the easiest crank to remove for cleaning, it takes 10s to remove and 10s to remount with a torque wrench.
PrettyA
by PrettyA
Thank you guys so much!
