Q Rings Chainline Issue
Need some help on my Rotor Q Rings. Please see this video:
http://tinypic.com/m/jickrk/1View%20My%20Video
As you can see there is quite some movement in the chainline. Does not matter how much I adjust the low, high or straightening screws I get chain rub. This happens in gears 52\13\12\11. I have managed to eliminate the chain rub on all others. Warped chainring? Is just the chainline is to out that it'll always rub a little?
Although I installed the Rotor Q Ring shim at 6 degree angle I still cannot change gears 36\14\13\12\11. Not a problem in itself as I wouldn't use these ratios normally. The inner ring does not have the movement that the outer ring gives.
I'm installing on a Giant defy Advanced Pro 0 with a Ultegra 6870 Di2 front mech.
Any help gratefully received.
That looks very different than the movement that I have seen on any bike I have run the 'Q'-Rings on. Generally, the movement is merely 'up and down', not 'in and out'. I would say that the rings are 'warped' as you say, or that something else is misaligned.
- jekyll man
Have you had the Rotor spider off the arm, and its not sat on the drive dogs properly when retightened?
Official cafe stop tester
gazzaputt wrote:[...] Warped chainring? Is just the chainline is to out that it'll always rub a little? [...]
I've had exactly the same issue with a 52 rotor chainring and a 6800 FD. No matter what I did to adjust it correctly, it would rub on the 3 lower gears. It took me a while to find out that the chainring was bent.
Last week I installed a shimano chainring and guess what ? Perfect and silent shifting now. But I miss my rotor big ring.
Okay swapped the outer ring for a spare ring video:
http://tinypic.com/m/jigtbn/1View%20My%20Video
I think there is less movement in without the Q ring would anyone care to agree?
I checked the q ring with a square and could not find it to be warped. Checked the crank tabs for the chainring bolts and to the eye they look okay.
Rear cassette checked all okay there.
Re mounted the Q ring and there is slightly less movement. I have fitted the extra QXL FD spacer which has helped to eliminate some chain rub but still get some in the 17 and 16 tooth.
I have another set of rings on the way to fit to my Ultegra crankset so I'll have a comparison then.
