Creaky Stem
ipenguinking
by ipenguinking
The FSA OS-99 stem on my bike was creaking badly. I regreased the four ti bolts securing the face plate with anti-seize before tightened them to 5NM. The creak was totally gone for almost 2 months. However I noticed the creak came back during this morning's ride. So my question is am I doing anything wrong? Is grease or loctite better for this application than anti-seize. Those bolts came with loctite but I cleaned them thoroughly before putting on anti-seize.
Btw I I tightened the bolts evenly so the gap around the face plate is the same. And I inspected carefully for all cracks.
logy
by logy
Similar issues with Ritchey stem and ti bolts. Pata
ChiZ01
by ChiZ01
do you have any garmin mount installed on the bar? make sure they are not too tight, one of mine was tightened too much, and caused the bar to flex and the stem creak.
ipenguinking
by ipenguinking
No Garmin mount. I have a PC7 mounted on the bar.
I've just repeated the procedure. But instead of anti-seize, I used Finishline Teflon grease. I rode around the block and creak is gone. I'm hoping it will stay this way for a while.
Asteroid
by Asteroid
Sounds like you isolated the noise to a certain area. One time I experienced creaking when the headset sealed bearing did not play nicely with its contact points.
Oldbie
alistaird
by alistaird
I prefer the idea of copper anti-sieze on the bolts to loctite. Hopefully you've cured the problem but I've found with a lot of creaks they return after 12 months :-(
A
sinikis78
by sinikis78
Even though you use grease a lot.... over power make them weak..... I think you had better
equip torque wrench .... and I have the same problem.... noise near the stem...so I suspect stem crack.... a little...
reknop
by reknop
sinikis78 wrote:Even though you use grease a lot.... over power make them weak..... I think you had better
Are you using any spacers under the stem?
Sometimes those start to creak when heavy load is applied ...
https://www.cycling-review.net
sinikis78
by sinikis78
actually I don't use spacers... but on the handlebar... there are lots of stuff including cell phone case...
I think because of that......
