Cables Inner and Outer upgrades Weight saving ? Performance ?
Looking to re do the cables on my propel -
what the opinion on upgraded stuff, I was looking at getting the dura ace cable set inner and outer
http://www.chainreactioncycles.com/shim ... prod130965
But then you'll need gear on top of that.
Any better options out there ? or is the basic LBS stuff good enough.
Tomstr wrote:I went for PFTE coated inners for shifting and braking. I have to say they work very well. No hassles in setup or anything.
Cheers for the reply, did you stick with basic outers ? Did you get them from a LBS or online ?
Seen these as well, expensive but a claimed 20% lighter ? not sure about cable run with these though !
http://www.wiggle.co.uk/jagwire-road-el ... -gear-kit/
Yes, I've cleaned the outers first but didn't replace them to try PFTE inners first. Replacing the outers is planned to make the routing a bit smoother. Running a 130mm stem slammed needs a bit more cable that it has out of the factory.
The shift routing through the frame was simple enough, the rear brake routing was a bit more fiddly but you only have to do it once so no worries.
[edit]
Those Jagwires look nice as do Nokon's but when you ride all weather or dusty terrain I'm afraid you'll start hearing them at some point.
[edit]
Ride it like you stole it
Have had good experience with Jagwire Pro teflon-coated kits (the black cables, braided housings). Overall a bit lighter than OEM/Shimano cables (-20g on my Scot, fwiw) and very smooth.
'19 Santa Cruz Blur TR, CC, X01, XTR, Fizik Tundra 2.
'15 Giant Defy D-A, Hunt + ProOne, Fizik R1. Endurance machine.
'06 Scott CR1 D-A, Ksyrium SL + GP4kS, Aliante. Climber. Mostly retired...
Jagwire makes an elite sealed kit too if you're worried about the links being noisy.
- prendrefeu
- Contact:
Find Tune housing. Remove outer sheath, use inner liner as your housing. You will not need a liner, either, this will be an all-in-one-housing.
Use Ti or Powercordz for weight savings.
That will be your lightest setup.
- prendrefeu
- Contact:
eBay.de
Just a small heads up if you are colour conscious: the inner sleeve of the Tune housing is white. It only comes in white and it can *NOT* be changed to a different colour... I've tried every method that would not add mass.
- DWatkinsBSB
prendrefeu wrote:eBay.de
Got these bad boys. How do I remove the outer to be left only with the white bit?!?!?!
