Campagnolo Super Record Rear Derailleur. 32t?
Ultimatek
by Ultimatek
I am currently using wifli SRAM. I try to use a Campagnolo Super Record is used as a 32T sprocket Sram .
Can I use this combination? :?:
graeme_f_k
Shop Owner / Manufacturer
by graeme_f_k
If I understand correctly - you want to use a SRAM 11s cassette with a 32T biggest sprocket with Campagnolo SR?
In some cases you can make it work but it is not recommended and the derailleur was never designed to cope with that size bottom sprocket - 29T max.
The sprocket spacings on SRAM / Shimano are not exactly the same as Campagnolo either, so although it *works* it's not exactly right, so again it's not to be recommended, especially asthen you are doing two things that are outside the design specification.
