Valve length for 50mm rims
Stolichnaya
by Stolichnaya
Silca's site has a nice valve extension fit guide graphic:
https://silca.cc/collections/silca-acce ... =819395693
rlarldhks86
by rlarldhks86
I use 80mm valve.
60mm valve is shot
tmr5555
by tmr5555
Don't use longer valves than you should. It throws the wheel balance off. 80 MM is simply not necessary. Pro mechanics often take off the extenders once they inflate the tyre.
burglarboycie
by burglarboycie
The 60mm valves on Continental Supersonic tubes leaves just enough room to get my track pump valve on so its all good!!
Lugan
by Lugan
mimason wrote:I have 50mm rims and use 60mm tubes, you should be fine.
Same here (Bora One 50 clinchers and Conti Light tubes)
hongsj
by hongsj
80mm
ryanw
by ryanw
I have Zipp 404s (58mm deep) and I use Continental Supersonics 60mm. My track pump fits, just.
Used to use Continental Race Lite tubes with an 80mm valve.
Since this is weight weenies, I would go with the 54g 60mm Supersonics!
IG: RhinosWorkshop
