Bike Mechanics in London
Hi,
I just moved to Barnes (SW13) and would like advice on best local bike shop or mechanics in this area of London.
Am about to start building a bike and will definitely need some help and advice, would love to learn and do it myself but will be expensive if I mess things up.
On a side note, what is the best way to approach learning how to build a bike? I'm almost tempted to buy e-tap instead of super record mechanical just because it'll be easier to set up...(half joking about this)
Advice would be welcome, will start a build thread once I get started
Thanks
Thanks
I built my first bike (http://i.imgur.com/dqPgc8p.jpg) the other month. Almost everything I needed to know I could get from one of the following resources:
a) YouTube
b) Forums
c) manufacturer websites/support documentation
d) Park Tools website
Having the right tools will also make your life very easy. I didn't have a few things - headset press, derailleur hanger alignment gauge, bottom bracket tap/face tool, hacksaw/cutting guide to chop streerer tube, and had a local workshop do these for me (Bespoke Cycling on Jermyn Street, as well as Condor Cycles on Grays Inn Road). The tools I invested in are (and I'm sure people will say some of these aren't essential):
Cable cutters
Cassette lockring tool
Bottom bracket wrench
Torque wrench
Set of allen keys
T25 key
Chain tool
...I think that's all. I may have missed one or two!
Regarding local shops, that's not my stomping ground so I can't really comment - I'm sure there will plenty in that neck of the woods. Good luck!
a) YouTube
b) Forums
Cable cutters
Torque wrench
Set of allen keys
T25 key
Chain tool
condorman wrote:Hi,
Thanks
There are some great videos that cover just about every aspect of building a bike.
The best way to learn is to get stuck in and have a go. You may make mistakes but that is how you learn.
I can just about put my bikes together OK. I got fed up having to go down the LBS just to get headset adjusted or setting up my gears etc. Take your time try not to get frustrated and have some spares cables etc just in case.
not been in them, but i've got family in the area so see a couple of shops...
Bikes & Bits
66 Mortlake High St
Pearson Performance
232 Upper Richmond Road West
for buying stuff, you'll be a short ride from kingston, the sigma sport shop there is very good
Bikes & Bits
66 Mortlake High St
Pearson Performance
sungod wrote:not been in them, but i've got family in the area so see a couple of shops...
Bikes & Bits
66 Mortlake High St
Pearson Performance
Thanks so much for this!
You can quickly end up spending a lot of money on special tools for jobs, depending on what kind of bikes you're building. Things like pressing/removing BB-bearings, installing cranksets and so on. But it really depends on the frame etc.
My advice would be to slowly replace your little toolkit with quality tools from brands like Pedros, Park, Unior as you need them.
If you are building a bike you consider putting E-tap on, you are in a budget range where a torque wrench most definately will be needed. And I would get some cone spanners as well.
if you're building from scratch, a rear mech alignment tool will be useful, there are ways to improvise but a proper tool makes life easier
i've got one but it's heavy, after needing one on my last trip overseas i recently made a weight weenie version out of carbon fibre, i even realised i could design it to allow use without removing the etap rear mech, for my next trip it will be in the bike box, weighs about 100g
viewtopic.php?f=3&t=139618&start=15#p1240162
