What is the best weight/$ finishing parts (seatpost/handlebar/stem) these days?
Wingnut
by Wingnut
Thanks tarmackev!
dmulligan
by dmulligan
Kurets wrote:
dmulligan wrote:I've had great luck with this seat post http://m.ebay.com/itm/Newest-3k-Full-ca ... nav=SEARCH
Just recieved an identical seatpost like the one above (although bought from Aliexpress and not Ebay) and it had very poor roundness once you got within 15 or so cm of the seat clamp. The seatpost is oval 27.6mmX27.3mm. Did not pay more than 15€ for it so I won't cry when it goes into the rubbish bin.
Mine doesn't get inserted quite that far so I've not noticed.
Sent from my Oneplus One using Tapatalk
namejoker
by namejoker
Kalloy UNO 7 stem
Under 30$ on eBay
110gram for 100mm
Weight can be lower with Ti bolts.
Thomson Masterpiece Post
Under 130$
150ish for 27.2*240
Can be tuned to sub 130gram with aluminium upper yokes and Ti bolts and swivels for under 20$.
I've been using both all the time !
Sent from my MotoG3-TE using Tapatalk
vejnemojnen
by vejnemojnen
a 130mm de-badged uno stem came in right at 121 grams. It was around 20usd back then last summer.
RyanH
by RyanH
Deda Elementi Tape is usually <30g finished at $12 shipped. The included bar ends are also on the light end at 5g for the pair.
stockae92
by stockae92
Pulled the trigger on a Hylix carbon seatpost with 2 Ti bolts. User opinions seems to be good in general.
