Fizik R1 carbon rail; loose...
TheDarkInstall
by TheDarkInstall
Hi
Has anyone had the carbon rail on their R1 develop play in it, where it enters the seat at the rear?
The right side rail on my R1 has a bit of play in it, which makes a clacking noise when I am writhing my taint about on it, under power.
If you have, did you find a way to fix it? Seems the whole seat is glued together, so taking it apart doesn't seem an easy option. Willing to try to fix it the hard way, of course, if anyone has any suggestions they have tried which worked.
superdx
by superdx
Mine also creaks, I had a look as well and found the whole thing glued/bonded together. My Google on this issue seems to be people trying to put lubricant or mineral oil at the glued areas and that seems to have worked? It didn't really understand how applying lube to a glued joint would make it creak less so I didn't really give it a try. Saddle is sitting in a box unfortunately, and Fizik didn't respond to any emails asking for advice.
chiumomo
by chiumomo
http://www.fizik.com/rw_en/qualityclaim/
Try this, usually have quick response
wheelsONfire
by wheelsONfire
If your saddle creaks it can also be when it moves (even micro-movements).
I think people use silicone spray to stop this. You can spray at the nose and rear attachments rail to saddle shell.
It does not damage anything. So a good test is using silicone spray.
Some saddles rails also creak in in the junction with the seatpost mechanism. You can even spray this with silicone spray.
Some people use silicone spray at titanium frames to avoid dirt getting too stuck at the frame.
It is easy to wipe of with dishwash soap and water.
Bikes:
Open *UP* (2016.04.14)
sanrensho
by sanrensho
Do a search using the keywords "Specialized, saddle, loose, rail."
I don't use Fizik but I have had several Specialized saddles that developed loose rails. I have seen a loose rail-saddle connection successfully bonded, although I haven't done it personally.
TheDarkInstall
by TheDarkInstall
Thanks for the replies!
I took the seat off and had a look. The bond on the creaking side has cracked off...
The seat is over 2 years old, so out of warranty (already tried Fizik for this...)
Can anyone who knows their stuff about bonding / epoxy, etc., recommend a good product reapply the bond in this section, and if possible give me an Amazon link with the product in question...
Cheers!
glepore
by glepore
JB weld-any hardware store. Get the real stuff, not the 5 minute.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
TheDarkInstall
by TheDarkInstall
glepore wrote:JB weld-any hardware store. Get the real stuff, not the 5 minute.
Thanks a lot. That stuff looks pretty hardcore. So, the standard stuff and not the 'Kwik' version they have then.
Will get some and see how it goes.
Appreciated!
WannabeWeenie
by WannabeWeenie
Another good glue to use is Loctite Black Max 380. Unlike most cyanocrylate glues, this one has quite a bit of flex to it. I have used it as resin to infuse small CF patch repairs and it works great.
Also, this should flow into the joint better than JB Weld and produce a cleaner repair. Just be sure to compress the joint until the glue sets.
Loctite 38004 380 Black Max Instant Adhesive, 3 Gram Tube https://www.amazon.com/dp/B00BWEQL1U/re ... Oxb1S9M1FJ
TheDarkInstall
by TheDarkInstall
Bought some of this on Amazon, and finally got round to fixing the rail.
Mixed the two parts, stirring it with a credit card, and got high off the fumes. Just like the good old days in the toilets of Gatecrasher.
It went on easy, and I spent a while shaping it perfectly, just like the good old days of doing Warhammer miniature conversions with DAS.
Left it to dry and set for 24 hours. Just went out for a ride. Perfect! In fact, it is actually better than the left side now, which flexes and creaks slightly too. Might do that side as well, turning my seat into an ultra-seat.
George46GR
by George46GR
TheDarkInstall wrote:
Fri Aug 19, 2016 11:13 am
Could you please upload a photo of your fix? Thans a lot, George.
2023 Cervelo S5, size 56, sapphire/ice
Ypuh
by Ypuh
Had the same problem on one of my Fizik R1 saddles. It made louds clicks as if the frame was broken, so I was very glad (but also disappointed) it was the saddle.
Didn't like the particular saddle anyway and traded it in for the R1 open which didn't have this problem. I believe the answer is already given here in that it needs some glue/epoxy on where the saddle rail meets the shell.
Cervelo S3 - 7.3kg
Time ADHX - 8.7kg
