Giant TCR Advanced SL 2 2017
An upgraded 2017 KOM SL2..... I think I want. Even though I have the yellow SL2 with pretty much the same finish.
https://www.instagram.com/p/BJjbhM5DWIl/?taken-by=edenbicycles
Carrots wrote:An upgraded 2017 KOM SL2..... I think I want. Even though I have the yellow SL2 with pretty much the same finish.
Cool, I've got the Yellow Sl 2 as well. What are your impressions of it ?
While not an aggressive set up, there is nothing wrong with Brus's fit. What is certain is that there would have been a pile of headset spacers to get his needed stack height on an ML. Assuming that set up is comfortable it is 100% fine. 186 cm can work on a large.
Of course there is nothing wrong but that doesn't mean it is the best option right? And what's the point of getting a proper race frame as the TCR and not having it built with a proper agressive fit?
There is no way that massive frame is stable with such a small stem (90mm?)
I am not sure if he needed to had any extra spacer with a ML. With such a small drop there is only one of these 3 options that is right:
- his agility is equal to 0
- he his >60y old
- he still doesn't understand anything about a proper fit
I believe the correct answer is the last but it would have been more helpful to ask before
Anyway, you'll love the TCR! It's a blast!
- he his >60y old
damond wrote:There is no way that massive frame is stable with such a small stem (90mm?)
Dude, if you're going to run around criticizing people's bike fits based on a picture you should really get your eyes tested first.
There is no way that's a 90mm stem, looks more like 110 to me. And I'd say that's a pretty reasonable 7 or 8cm of drop. Not ultra-aggro but hardly Mamil-sportiver worthy either. Just because you run a frame size down from normal for your height doesn't mean everyone else needs to. And while bikes do look better slammed, spacers exist for a reason and they are there to be used as required.
Do you own a TCR yourself? While they feature what Giant calls the compact geometry and that's why they have a lot of slooping, they're pretty long frames for the size! My Medium has a 55cm top tube and the Large size has a massive 58cm!! This is more likelly a "regular" XL frame than a L. So would you recommend a 58TT frame for a 186cm person? I would not for sure!
But that's just my opinion, i think this guy would take much more out of the bike with a ML but hey, it's an amazing ride and he'll love the bike anyway!
I come in peace, no need to become agressive!
damond wrote:While they feature what Giant calls the compact geometry and that's why they have a lot of slooping, they're pretty long frames for the size! My Medium has a 55cm top tube and the Large size has a massive 58cm!! This is more likelly a "regular" XL frame than a L. So would you recommend a 58TT frame for a 186cm person? I would not for sure!
Long compared to what? The L TCR has exactly the same reach as a 58 Tarmac, 3mm longer than a 58 Evo and 2mm longer than a 58 H1 Trek (which has 14mm lower stack).
If I was recommending a frame for a 186cm person I would first tell them to ignore ETT because reach is a better measurement. And second the L TCR is pretty standard for someone of that height. Depending on other factors they're equally likely to prefer the L or ML.
Sure, but your opinion is based on thinking he's using a 90mm stem, which he clearly isn't.
wingguy wrote:damond wrote:While they feature what Giant calls the compact geometry and that's why they have a lot of slooping, they're pretty long frames for the size! My Medium has a 55cm top tube and the Large size has a massive 58cm!! This is more likelly a "regular" XL frame than a L. So would you recommend a 58TT frame for a 186cm person? I would not for sure!
Yes, and both of those frames are stated as a XL size! So, again, would you recommend a XL frame for a 186cm? i wouldn't!
My opinion is based on the overall proportions of the bike. Again, the frame is too long to be used with such a small stem and i bet the ISP was cut way longer than the marks it has.
Anyway, end of discussion for me. Happy rides for the owner with the monster of a bike the TCR is!
