EVOC bike bag - extra wheel set?
It can accomodate ONE pair in total - ie. two wheels.
The insides are too tight and might damage your wheels if you try and squeeze another set in.
I think the answer may depend on the vintage of the bag. I have used two bags purchased in 2012 to fly to cyclocross races and was able to fit size 56 disc brake cyclocross bike frames with one set of carbon wheels (disc brake rotors removed) in the Evoc's zippered wheel compartments, and a spare set of race wheels inside the bag. Note that I put thick Styrofoam tube wraps around the top, down, and seat tubes, and placed one wheel on each side of the frame, with the rear wheel on the none-drive side, then used Velcro hiking/back pack gear straps to secure everything to avoid movement. Another option if the bag fit is to tight, I also used wheel bags to carry on spare sets of wheels (cyclocross tires had to be deflated) on board flights and placed in the overhead compartments during flights with regular size Boeing and Airbus aircraft, but this is a non starter on flight using regional jets as the overhead bins are only half the size.
- Michael
Thank you very much for your answer
I can now confirm that it's possible to fit a set of wheels in the zippered wheel compartment and another set inside the bag with a size 58 road bike.
Sort of on topic, but I saw in the Eurobike coverage, EVOC introduced a replacement frame that secures the frame via fork and rear dropout or thru-axle. The downside is that it will cost more than 1/2 the price of a new Evoc bag.
- Michael
