Scott Addict di2 compatible?
chiltonp
by chiltonp
Are the newer addcits di2 compatible? Looking at a 2015 Addict Team Issue in the IAM color scheme. Are these frames suited for mechanical and di2?
Thoughts on frame as well?
Delorre
by Delorre
The never Addict's are mechanical or DI2, not both. If the hole on the right downtube is just a hole, then, it's a DI2 frame, if the hole is molded, then it's a mechanical frame. Mechanical frame 'could' be converted to DI2, but not the other way around.
I own one, and all I can say is, wow : really nice, light, stiff and good handling frame. Fairly harsh though...
tarmackev
by tarmackev
2017 addicts are as above, either mechanical or Di2. There's now a HMX or HMF disc version.
It's a very nice bike, light and stiff. Ticks all the boxes.
I do find them a little bland.
chiltonp
by chiltonp
thanks, based off of your description, the attached frame would be mechanical correct?
Delorre
by Delorre
mechanical, cfr molded hole on the don tube. See mine for the look of an electric version ;-)
BrunoDMS
by BrunoDMS
Hello,
Excuse me if you have already explained it (I don't speak English) so what's the "real obstruction" to the internal routing of Di2 cables in a SCOTT Addict SL?
The hole for the front derailleur cable?
The seatpost superlogic (incompatible with int.battery)?
The gauge of frame holes?
I've a scott addict sl and sometime I'm tempted to change it...
___
Sorry I don't speak English
