Zipp sl70 aero internal cable routing help
A2ON
by A2ON
Got some Zipp SL70 aero bars which allow internal routing of cables but as Zipp is owned by SRAM the holes suit SRAM not my shimano meaning the brake cable needs to have a tight bend and go over the top of the bar to fit into the hole.
Is this usual - anyone got mechanical shifters and fitted these bars with internal routing with success. ?
Any help appreciated
fh8425
by fh8425
i fitted mine with campag mechanical, no issue. Don't think there will be any issue with Shimano mechanical also.
Currently now on shimano di2, both the electrical wire and brake cable share the same hole.
A2ON
by A2ON
fh8425 wrote:i fitted mine with campag mechanical, no issue. Don't think there will be any issue with Shimano mechanical also.
Thats the dream mate, main issue here is knowing if you can move the cabe to the other side of the shifter.
AJS914
by AJS914
I had the Zipp Vuka Sprint bars and getting the cables routed was horribly frustrating. The bend at the drop was very sharp. It did work in the end though.
A2ON
by A2ON
ran them like this, due to both cables coming out one side and needing on on either side.
DamenH85
by DamenH85
A2ON wrote:Got some Zipp SL70 aero bars which allow internal routing of cables but as Zipp is owned by SRAM the holes suit SRAM not my shimano meaning the brake cable needs to have a tight bend and go over the top of the bar to fit into the hole.
I did it with Ultegra 6800.
damen
A2ON
by A2ON
damen
That looks brilliant - Do you mind telling me did you do the same as me with the routing mate ? to address both cables coming out the same side ? Did you bring it over the top like I have pictured above ?
DamenH85
by DamenH85
A2ON wrote:
Did you do the same as me with the routing mate ? to address both cables coming out the same side ?
No, I have both housings on the inside curve of the bar.
damen
A2ON
by A2ON
Like this but obviously ours come on the inside anyway ?
DamenH85
by DamenH85
A2ON wrote:Like this but obviously ours come on the inside anyway ?
Yes. I might have a photo at home that I can post later today.
damen
A2ON
by A2ON
damen
That would be fantastic !
DamenH85
by DamenH85
A2ON wrote:
//image removed
damen
This is the best photo I have of the housing detail. Hope it helps.
damen
A2ON
by A2ON
Perfect thank you !
