Vittoria Pave tubular width
1415chris
by 1415chris
Can somebody chime in with the actual Vittoria Pave CG III tubular 25mm and 27mm width?
I know that Open versions run slightly lower than declared and was wondering if that might be the same case with tubs.
beeatnik
by beeatnik
Hoping the 25's run small so I can ride them on my C59.
RyanH
by RyanH
I can't measure until I get back from my trip but I recall it was almost exactly 27mm for the tubs.
Sent from my SM-G930V using Tapatalk
duvivr6
by duvivr6
I have ridden 25 Paves on my C59 with zero clearance issue. They are one of the tire that fits with space to spare.
I tried some Michelin 25 clinchers that measure more like 27 and it rubber the paint off my fork :(.
mrgray
by mrgray
in my experience 27 mm on hyperon were like 0.4 mm wider than 25 mm. that is of course a 20 mm rim. actual width on wheel was in order of 24.5 mm as i recall. can measure when i get home.
25 mm ran fine on c59 and c60 (and eps for that matter).
Bobo S&S Steel Bike - 7.5 kg
Oltre XR2- 6.6 kg
Look 585 - 6.8 kg
Look 695 SR :D
RyanH
by RyanH
Just for clarification, the OP was inquiring about tubulars not clinchers
1415chris
by 1415chris
Thanks for the info.
New Vittorias G+ started appearing in reasonably good prices, tempted by 28mm.
Did anybody have a chance to measure the actual width of that one?
tomycs
by tomycs
25mm Vittoria Pave CG III tubular on 25mm wide carbon rim @105psi was 25.1mm (but experience is based on n=2 only)
dogrange
by dogrange
The 27 tubs are only about 26, at least the ones I have. No problems on dogma f8.
