Scott S40 Headset Bearings Removal - ****FIXED!!!*****
The steering on my S40 feels "NOTCHED" at the centreline, in fact the steering settles there but is otherwise smooth. I want to examin and replace/grease the bearings. I have removed the headset cap and stem. I have used a rubber mallet to free the steering column but it refuses to move - is it seized or am I doing something wrong? Please help if you can.
The forks should just drop out once the stem, spacer, top cap and top race are removed.
I remember the fit between the fork and the bearings being very snug on my S40, so much so that when I got the forks out with a mallet the inner race of the bearing came with the fork. As long as everything is removed from the top, you can't go to far wrong tapping the forks out with a mallet and being careful
Ok how to I remove the "top race"?? there doesnt seem to be any obvious way - I have searched youtube for instructions but they all seem advise that once the top cap, spacers and stem are removed the forks should just drop out - I have used quite a bit of force with a rubber mallet and those forks are not budging.
- bikerjulio
See the split compression ring in the middle that sits into the top bearing? Hit the steerer hard enough to move it down about 1/4". Then lift the fork and separate out the split ring from the bearing and remove it. Fork will then drop out.
Regreasing will not fix your bearing problem. You need new ones. A ghetto fix is just to swap the bottom and top.
Did you remove the plug as already reccomended?
There's sometimes a buggy.
One.
One.
I havnt removed the plug, as its internal, I cant see how it would affect removal of the forks??? Also, I have really given the steerer several hard whacks with the mallet and its not budging one bit - Im afraid if I use any more force I might break something. Yes I could take it to a bike shop but my wife, who is the breadwinner was diagnosed at treated for breast cancer so we are living hand to mouth, so there is no money for a mechanic so I am grateful for any advise in getting this sorted
As a couple people have mentioned... Remove the internal expander plug. These almost always expand a steertube enough to make a tight fit even tighter. Especially if the steertube is of lighter construction. Remove it, whack it, and done!
Ok, alloy steertube. Perhaps there a bit of seizing that's occurred between the steertube and the bearing itself. In that case is use some penetrating oil around the steertube and inner race of the bearings (both upper and lower), let it sit and penetrate for a while, then have at it with a mallet. At the end of the day, it's gotta come out and that's the only way, if he hasn't gotten it out already. It's been a few days since his initial post. And my mistake on assuming a carbon steertube. If it's alloy, the starnut should not have caused any expansion of the steertube. Thanks for clarifying @Fiery.
Ok I will use penetrating oil and attack again with the mallet! Fingers crossed.....
WOW - SUCCESS! I used a small screwdriver and prised off the split ring and top bearing housing and the forks fell out! 3 days of penetrating oil did nothing, nor did repeated bashing with a rubber mallett! I took the bearings out and it appears paint overspray on the inside of the head tube had gotten onto the bearings, so cleaned them all up and smothered the bearings and housing etc in bearing grease. When I put the bearings and fork back together the excess oozed out - hopefully leaving plenty in to repel moisture, and the forks turn nice and smooth - Amazing! A big thankyou for all your help! (twas a zero stack headset)
