Reducing Press Fit seal drag
LouisN
by LouisN
I'm trying to figure out a way to reduce the drag on a Sram Press Fit (PF30) BB cups.
I'm under the impression that the cup seals add a lot of drag to the ensemble.
Any ideas/solutions to help ?
:beerchug: thanks !!!
Louis :)
RyanH
by RyanH
I'm curious about this as well, my PF86 frames, I can barely get the crank to rotate a half revolution on its own.
Sent from my SM-G930V using Tapatalk
ms6073
by ms6073
LouisN wrote:Any ideas/solutions to help?
Not sure if this is still the case, but when SRAM first introduced the PF30 assembly, there were two sets of seals, for which removing the outer seals helped reduce rotational drag. My solution was to replace the SRAM assembly with a 3rd party BB, which at the time, I went with Cannondales PF30 solution, but Wheels Manufacturing or similar would be cheaper.
- Michael
ms6073
by ms6073
RyanH wrote:my PF86 frames, I can barely get the crank to rotate a half revolution on its own.
What cranks and bottom bracket? In my experiences with BB86, binding like that typically indicates that either the bearing cups are misaligned or the bearing races are experiencing too much preload.
- Michael
LouisN
by LouisN
I had a Wheels Manufacturing PF30 BB installed but it was misaligned ( by the BS :x ) and I experienced what RyanH is talking about.
Removing the cups was hell, as the BS mechanic had put Loctite on the BB cups. I had to use a saw to cup the alloy cups in 4 pieces, and then remove them... :x
Yeah, the Sram external seals have a thick outside lip and maybe that's what causes the most drag.
Thinking about maybe using another type of external seal or spacer. Not the best in wet weather though...
Louis :)
cobrakai
by cobrakai
I'm not exactly sure what those bearings look like but I have read about people removing the inward facing seal since it is less likely to be exposed to dirt and moisture. It will probably still have a negative effect on the lifespan of the bearing though.
addictR1
by addictR1
I use the BB86 GXP ceramic on my Addict and was about to get 4.5-5 full revolutions. The non-ceramic version from SRAM on the other hand yield only 2-3.
Now using Hawk Racing and brand new installed gave me 7-8 revolutions.
nickf
by nickf
My stock sram PF30 bearings spun well when i had the seals removed for a clean/ regrease. I installed the cranks without the seals in place just to see how they would spin. Really well. But you snap the seals back in and your lucky to get a a few revolutions. I have the Hawk bb now and they are effortless with seals in place. They did have to break in first. Its not like the seals in the hawk bearings are loose. Looks like a bearing to me. They have been though many rain storms and still spin effortlessly and smooth. Maybe the material of the seal isn't as slick or to soft causing more friction in the sram bearings?Maybe trim inner material from the seal edges?
addictR1
by addictR1
nickf: thanks to your suggestions.. i got hawk and really enjoy using it. i emailed them asking how to service it and was surprise to hear not to open them up and just wipe the outside clean and add a couple drops of white lightning as needed.
Gearjunkie
by Gearjunkie
Ok, I'm over my PF30 Cannondale Evo having way too much drag so I think you've convinced me on the Hawk.
So do I need the PF30 Hawk (and so will have to go through the whole Locktite prep and seal thing) or can I just buy the Hawk BB30 bearings and use them in my existing PF30 cups?
Or is that just a bad idea? (not worried about cost, just ease of successful drag free, no creak install).
Cheers
GJ
addictR1
by addictR1
Gearjunkie wrote:Ok, I'm over my PF30 Cannondale Evo having way too much drag so I think you've convinced me on the Hawk.
Cheers
GJ
GJ, depending on where you are located.. if you are in US.. i can give you the link and the promo code to save on buying the PF30 Hawk. i bought two set of BB86 for my Addict R1 & TMR02. i'd say just replace the whole thing and install the hawk. since installing it.. i don't have any creaking issue. since installing hawk.. i've been bettering my own PR every time i ride the same climb.. maybe that's all mental. haha
Gearjunkie
by Gearjunkie
Hey, thanks for the offer, very kind. But I'm in New Zealand (little Country in the South Pacific near Australia.
When you installed your Hawk PF30, did you use any loctite or just press it in?
addictR1
by addictR1
GJ: no problem. no i didn't use any loctite. never had to use that. on both of my frames, i just put a super thin coat of grease on the HAWK and press in.
Gearjunkie
by Gearjunkie
Great, thanks!
:thumbup: :beerchug:
