Colnago v1-r bottom bracket
pdiomidis
by pdiomidis
Hello, just a simple question, can you tell me what bottom bracket should i buy for Colnago V1-r frameset to install a Campagnolo Chorus 2015 crankset? Just from a simple search i found that this frame uses a so called Tread fit 82.5
Can you link me the bb cups from a web-shop?
Thanks in advance,
Regards,
Panos
TomColnago
by TomColnago
Hi there, the threadfit 82.5 is a sleave that threads into the frame which you press BB86 cups into so the frame isn't damaged if something goes wrong in installation and you just get a replacement sleeve. I believe for a campagnolo crankset you will need this bottom bracket but check with your lbs as I'm not clued up on the v1r but I think it's the same as a C60
http://www.wiggle.co.uk/campagnolo-ultr ... 60693885uk
pdiomidis
by pdiomidis
TomColnago wrote:Hi there, the threadfit 82.5 is a sleave that threads into the frame which you press BB86 cups into so the frame isn't damaged if something goes wrong in installation and you just get a replacement sleeve. I believe for a campagnolo crankset you will need this bottom bracket but check with your lbs as I'm not clued up on the v1r but I think it's the same as a C60
Ok that means i need bb86 cups generally.
Do you know also the diameter on it's bottom bracket?
joeyb1000
by joeyb1000
Correct. Use Ultra Torque BB86 cups. Same as C60. 41mm diameter. Also, there is a product called Mr. Ride (on Ebay) that replaces the whole Colnago shell, but I have not used it.
Calnago
In Memoriam
by Calnago
Just to clarify a couple things mentioned... The "sleeve" in the BB of the C60 (which I'm pretty sure is the same as the V1-R) is not replaceable. It is an integral part of the bottom bracket. And it is threaded. The Threadfit cups thread into this sleeve. These cups are what are replaceable. The Ultratorque cups from Campagnolo then press into the Threadfit cups on the Colnago.
The Mr. Ride product is simply an alternative to the Threadfit cups themselves, not the alloy sleeve that's part of the BB. It may have a protective sleeve between the two cups but that's just to protect the spindle and prevent rubbing of wires on the spindle if you're using EPS or Di2.
pdiomidis
by pdiomidis
Thanks alot for you answer guys, i won't change anything on the sleeve that is coming already with the frame, just need to see what cups i need to mount campagnolo cranks.
So 86.5mm x 41mm bb86 cups are fine! I will head to buy them.
One more question, do you think 50s size is ok for 1,72 height with inseam 81?
corky
by corky
pdiomidis wrote:Thanks alot for you answer guys, i won't change anything on the sleeve that is coming already with the frame, just need to see what cups i need to mount campagnolo cranks.
You can make it work but I think maybe 48s is better.... I kinda have the same question and am 173 height.
pdiomidis
by pdiomidis
i think 48, has too short tob tube, i never ride 52x mm top tube, all my bikes top tubes was above 535 and was with 13 stem and worked perfect.
Also seat tube is 450, imagine i seat on 72.3 so i would have too much seatpot as a result way too much drop.
corky
by corky
Well we're all different, I currently ride an extreme Power horizontal top tube 54(50s)with 110 stem, couldn't go any longer without dropping to a 53cm(48s)frame.....but I do have relatively short arms
