23 mm tires on a C17 (25 mm) rim
I have been using Shamal C15 and Hutchinson Fusion 3 tubeless tires. I am considering buying a new Shamal C17 rim but I have many Hutchinson 3 tubeless tires left. Can I use the Hutchinson 3 tubeless 23 mm tires on this rim that was designed for 25/28 mm tires.
Thanks for your help
-=terry=-
-=terry=-
- Frankie - B
- Admin - In the industry
This Ertro legend says it can't:
but Paul Lew tells us that on Reynolds wheels you should for aerodynamic efficiency.
link to the quote.
The rim width is now 25mm, making it possible to run the Assault with 25mm wide tires, or if you want to grab a little extra aero benefit, you can stick on some 23mm tires. The wider tire profile will give you a better ride whether you are on the road or gravel, while running tires narrower than the rim will aid in disrupting and reattaching the airflow over the rim.
link to the quote.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!'Tape was made to wrap your GF's gifts, NOT hold a freakin tire on.'
- Frankie - B
I just looked it up and C17 is indeed Campy talk for 17mm rims.
The ERTRO legend is leading, but also please look at the quote I posted. On my wifes bike I have mounted 23mm tubeless tires on Reynolds Attack wheels. The front wheel of my own bike (assault wheel set) is also a 23.
