Scott Foil 10 - Issue with Saddle Post Screw
bleko
by bleko
Hello All,
I overtighten the screw of the saddle post of the Scott Foil 10.
I can't use it anymore as the inside of the screw is damaged.
What do you suggest me to do in order to replace the screw and fix this issue ?
Thx you all.
RyanH
by RyanH
It should be one size smaller than a bottle screw so M4, maybe m3? You could probably pick up a replacement at the hardware store while your local dealer orders a replacement from Scott. I think I'm going to replace mine with an Allen bolt anyway instead of torx so I can get to it on the road.
Sent from my SM-G930V using Tapatalk
