I ride a Tarmac Sl4 S-works. I pressed in a C-Bear shell with Italian thread to fit my Campagnolo ultra torque crankset. I made a Specialized Tarmac with Italian bottom bracket.
It worked very good. I used my Campagnolo Record groupset without problems on my Tarmac sl4 s-works.
I recently bought Sram Etap. I bought it with GXP crankset. I thought that I can use the C-Bear shell that is already pressed in (secured with removable Specialized epoxy) and only srew in the Truvatix GXP drive cups with Italian thread to make it work with the GXP Sram Red cranckset.
I wonder now if I made a correct assumption? With the pressed in C-Bear shell the bottom bracket is now 69,60mm wide. When I look at the Sram GXP bottom bracket instructions, do I need the extra spacers before I srew in the GXP drive cups?
https://www.google.nl/search?biw=1920&b ... _izguLM%3A
Thanks!!!
Need help on bottom bracket
Specialized Tarmac S-works SL7 (Satin carbon spectraflair tint)
Specialized Tarmac S-works SL6 (Green Cameleon)
Specialized Tarmac Pro SL6 Disc (Blue/Teal Sram Force AXS)
Specialized Epic Elite 29
Greetings from the Netherlands
- bikerjulio
An Italian BB is 70 mm wide. SRAM instructions can be confusing IMO but you should not need any spacers on a road setup, either English or Italian.
Your link does nothing to help.
There's sometimes a buggy.
One.
One.
Spacers are for MTB cranks, because MTB has a number of threaded BB widths, first original road BSA, then another to increase chainline for tire/stay clearance, and once again for rear suspension.
[14lb(6.35kg) of no carbon fiber]
[2lo8.wordpress.com]
Thank you!
@Bikerjulio: I added the link to show the spacers in the Sram GXP instructions.
