adding weight to reach 6.8kg
rideintospace
by rideintospace
My girlfriend (BMC SLR01 owner) is planning on racing a UCI race this year and needs to add weight to her bike to reach 6.8kg (around 800g). Any ideas on weights that could be added in the seat tube or around the BB area to accomplish this??
It feels so anti-ww
dudemanppl
by dudemanppl
Looking at your build, I'd recommend getting a burlier stem and maybe like a SRAM 1130 or Shimano 5800 cassette, that would be 150-200g right there already.
rideintospace
by rideintospace
cassette I can do, stem is working great and don't want to accidentally change the position on the bike by switching that out. good ideas. She will use a heavy set of 808 wheels and clip-on aero extensions for the TT stage, and potentially keep the 808s for the criterium stage, but 3 RR stages require the bike to be set up like this. Ideally there is a solution for adding BB weight? I think that would help keep the center of gravity low while meeting minimum weight.
BOB78
by BOB78
I guess they will not add much but what about some heavier skewers?
2lo8
by 2lo8
Skewers can add a lot of weight if you get some old school steel internal cam skewers. Some are over 200g per pair, so that's +170g.
[14lb(6.35kg) of no carbon fiber]
[2lo8.wordpress.com]
han1337
by han1337
Training wheels?
Gesendet von iPhone mit Tapatalk
grouk
by grouk
pedals, cassete, tape cages garmin mount...
jeffy
by jeffy
wouldn't it just be easiest to add weights into the spindle?
2lo8
by 2lo8
As far as I know, there's nothing off the shelf like that. It's not exceptionally difficult to do, but it does requiring having some custom machining done if you want it done well. The closest you would get would be to try and find a pipe expander that small.
rideintospace
by rideintospace
2lo8 and jeffy, thanks for the advice. not trying to switch out too many components. the cages, tape, garmin mount, etc, etc, etc work really well. cassette and skewers are an easy switch that could add up to maybe 200g?
had never come across a pipe expander before but trying to find something that will fit inside the GXP spindle now :)
2lo8
by 2lo8
Pipe expanders are just like the expander plugs in a carbon fork steerer, except they're big, heavy and made of steel. They're used to expanding exhaust pipes so you can join them and slip one over the other.
HammerTime2
by HammerTime2
A Vivax Assist will easily get the bike over 6.8 kg. And most of the weight is fairly low on the bike, in the seat tube and BB area, right where you want it. The extra W's you get more than pay for the extra g's.
Let the commissaires weigh the bike all they want. Beyond that, what they don't know won't hurt them.
spdntrxi
by spdntrxi
I thought an onboard camera counts now... a go pro or a virb would be easy weight to add and get some cool footage at the sametime.
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
pdlpsher1
by pdlpsher1
Make sure the extra weight is not rotational weight.
RyanH
by RyanH
This should be 1.1kg worth of lead shot. You could make a holder (bag or something) and secure it in the seat tube above the BB, just make sure it doesn't touch the spindle.
