Iphone 6 mount for racing bike
by bleko
Hello Guys,
I just bought a Foil 10 2016 and would need a good iphone holder...
Which one between those two mounts would you recommend ?
Thanks you !
by phallenthoul
You should check out topeak mount.
by Wheever
Actually, you should look into getting a wahoo RFLKT and keep your iphone in your pocket. I just started to do that, and am much happier than when I was using an iphone mount.
by shoemakerpom2010
I have been using this for about two years now and it works fantastic. The only downside is topeak software doesn't connect with strava. You can run the strava app if you need that. It also works great with their cadence sensor.....
http://www.topeak.com/products/PanoBike ... e_ip6_plus
by Point
I fully recommend the Quadlock stuff. They do an out-front mount now as well as a bar or stem mount.
by bremerradkurier
Been pretty happy with my Bryton GPS head unit-run time is incredible
https://www.amazon.com/Bryton-Rider-Cyc ... +rider+310
by glepore
Huh? Buy an aero bike and stick an iphone on it?
Cysco Ti custom Campy SR mechanical (6.9);Cannondale SS Evo Di2 7970 (5.79); Willier Cento Uno Air Di2 9070 (7.0); C40 Mk2 DA 7800 ; Anvil Custom steel Etap;1996 Colnago Technos Record
by 2lo8
iphone 6 is very aero. 7mm thick. 158mm long. That's something like a 23:1 aspect ratio. Show me a Garmin that aero.
[6.6kg of no carbon fiber]
by Roni1
Rokform is better
by BeeBee30
I went from running iPhone 4s a 6 with a Topeak mount and then very quickly to a Garmin as I didn't like having a small camping table mounted to my handlebars :shock:
Ti or dye!
by lewolive
My experience on Quad lock/Iphone6 is great, with 25000km of pleasure. It's safe for the iphone and offers a good protection in case of light rain.
I also use the Quad lock case all the time in order to protect the phone.
I'll probably buy the next QuadLock for Iphone 7 this Fall...
by mpulsiv
by AJS914
I'd be hesitant to put a $600 iPhone in place where it could easily get damaged in a crash. I've had several cyclometers get damaged in crashes over the years.
by Zakalwe
2lo8 wrote:iphone 6 is very aero. 7mm thick. 158mm long. That's something like a 23:1 aspect ratio. Show me a Garmin that aero.
Show me anyone mounting their 15.8cm long iPhone completely flat and not at ~10degree angle to be able to see it
by superdx
haha yup, iPhone screen is quite poor at viewing angles. Get a proper cycling computer. One light rain shower and your phone is toast
