Mavic CCU 2017
Cosmic Ultimate............... http://www.mavic.com/wheels-road-triath ... 1463895773
Ritxis wrote:Cosmic Ultimate............... http://www.mavic.com/wheels-road-triath ... 1463895773
The number 2017 tell you anything??? [emoji13]
Those these look like the ones on the Mavic site???? Come-on...
Enviado do meu C6903 através de Tapatalk
- zappafile123
hang on... are they clinchers? They allllmost look like clinchers. Hard to tell
FactorOne|SartoSeta|StorckF.3|Enigma EliteHSS|SworksSL6|ColnagoC60/V3Rs|DeRosa Protos|BianchiXR4/2|BMCSLR01 16|Cdale EvoHM|Focus IzMax|RidleyHe SL/SLX|BH Ulight|BassoDiamante|Scapin DyseysS8|TimeRXRS/ZXRS|TCR SL|RidleyNoah|Look585|CerveloS5/S3
I spotted the new Mavic CU at the 2016 Tour of California and posted some pics in this thread:
http://weightweenies.starbike.com/forum/viewtopic.php?f=113&t=137107&p=1235358#p1235358
Unfortunately I don't have any more info than what I posted then.
- wheelsONfire
You can see the difference in external weave for one!
A wider rim almost always gain weight over a less wide.
Why do you think Lightweight keep to those narrow rim profiles?
So the original CCU (20.5-20.8mm rim width) could be lighter than the forthcoming.
On the other hand, they hopefully have a better technology now, so they can make a rim both wider and lighter.
During 2015 Mavic head office told that the new CCU was expected 2017.
Hopefully they also designed better hubs
Bikes:
Open *UP* (2016.04.14)
- zappafile123
wheelsONfire wrote:Hopefully they also designed better hubs
That was my main problem with the previous version. The hubs were inexcusably bad for such an expensive wheelset.
wheelsONfire wrote:You can see the difference in external weave for one!
It can be possible to reduce rim wall thickness if the rim is wider and keep weight even/reduce weight.
Is this wheel definitely a new wider rimmed tubular CCU?
all they need now is a new hub! !
- cyclespeed
zappafile123 wrote:wheelsONfire wrote:Hopefully they also designed better hubs
Me too.
I still have a pair, but the rear hub is very basic, and the same as in much cheaper Mavic wheels.
Otherwise, a nice pair, much cheaper than Lightweights, and not so different.
- wheelsONfire
sawyer wrote:wheelsONfire wrote:You can see the difference in external weave for one!
Sure you can, but you can do this at a narrow rim to and then the narrow rim becomes lighter.
Bikes:
