It is currently Sun Jan 21, 2018 11:59 pm
Post new topic  Reply to topic  [ 205 posts ]  Go to page 1 2 3 4 514 Next
 Post subject: Chain lubricants
PostPosted: Sat Jun 25, 2016 5:26 pm
Not to ask what is best talking friction. I would like to ask what kind of lube is addressing least possible dirt?
I have used waxed based, ceramic, wet and dry and i constantly wonder why there is no really optimal lube?
What is really best if you like the chain as clean as possible at all times?
Bikes:
Ax Lightness Vial EVO D
Paduano Racing Fidia
Open *UP*
 Post subject: Re: Chain lubricants
PostPosted: Sat Jun 25, 2016 5:41 pm
Your mistake, because there is no lube optimal for ALL conditions.
Only for specific conditions.
PostPosted: Sat Jun 25, 2016 7:03 pm
I'm guessing paraffin mixed with graphite or PTFE. Actual hot melted paraffin, not wax based lube suspended in a liquid volatile solvent. It also helps to keep the outside of your chain as dry as possible whatever lube you use, lubricant is really only needed inside the rollers, or on low end rust prone SRAM chains.
[6.6kg of no carbon fiber]
[2lo8.wordpress.com]
PostPosted: Sat Jun 25, 2016 8:16 pm
Do you have an example lube?
Bikes:
Open *UP*
PostPosted: Sat Jun 25, 2016 8:31 pm
I think anything with good lubrication properties will attract dirt. The best advice I could give is to use a quality lubricant often to clean the dirt off. Most chain lubricants are mostly just solvents to suspend the active ingredients. The solvents will wash out any dirt that has accumulated on the chain. If one is willing to lube the chain after every ride I'm sure the chain will remain very clean and last a long time.
Once I saw a video showing tips on how to wash a bike. The video editor uses WD40 exclusively and he sprays the WD40 on the chain and derailleurs after a bike wash. He swears by it. I think the WD40 is mostly just a cleaner/solvent with perhaps a bit of active ingredients in it to maintain some lubrication properties. Maybe the OP could try that and report back the results?
PostPosted: Sat Jun 25, 2016 8:41 pm
That was GCN, comments were pretty rabid about that episode. That said, I trust those GCN guys.
PostPosted: Sat Jun 25, 2016 9:15 pm
I was talking about the friction facts type wax, where they melt wax to use as a liquid carrier for the solid lubricants, which has it's own issues, but unlike the others it doesn't rely on suspending lubricants in a evaporating, volatile solvent. Obviously you should wipe it off on not leave it all crusty with wax.
You should not get WD-40 in a chain, but if you make a paper towel just damp enough not to drip, it's very effective at removing residual lube on the outer plates. It has a very high solvent content, and a very small oil content, and the oil is simply not thick enough to serve as a chain lube, and you should be using lube with additives for plain bearings/bushings like those on chains. You can also use if for degreasing, it's better than a water based degreaser because the residual oil is not harmful, but also not better than just straight solvent, and the solvent should evaporate at room temperature, as opposed to water which can cause rust inside the chain and keep lubricant out.
PostPosted: Sat Jun 25, 2016 9:24 pm
I use hot parafine as chain lube. Works very well.
PostPosted: Sat Jun 25, 2016 10:31 pm
How do you apply the hot paraffin?
PostPosted: Sat Jun 25, 2016 10:39 pm
You stick a degreased chain in a pot with wax with with PTFE or graphite. No joke.
PostPosted: Sat Jun 25, 2016 10:49 pm
For me lube needs to be either a thin short term lube like prolink gold (mtb) or for the road bike a thicker lube like NFS. Metal on metal contact needs oil to reduce wear and prolong life. Wipe chain after every ride and add a few drops of lube.
PostPosted: Sun Jun 26, 2016 2:04 am
I like Boeshield T9. The aerosol cans are good. I just degrease (with park scrubber and purple de-greaser), water rinse (again with scrubber and water few times), dry, then lube liberally with T9. I wipe excess with a t-shirt type rag. It has to be done after a long ride 100+ miles or you can maybe get 2 medium rides out of that. That makes the chain like new. You can also degrease by taking chain off and put in a tupperware with solution. Shake and rinse. Chains also stretch as well as wear, and have to be replaced fairly often. I have tried tons of lubes and nothing works and performs as well as T9 and the above method for me. Something like Pro Gold I would need to re-apply that again after 50 miles or it would annoy the hell out of me, too thin and dry for long rides 100+ miles.
I guess the answer for you somewhat depends on your riding volume and conditions (wet or dry, pollen or dust in your area, etc.)
PostPosted: Sun Jun 26, 2016 2:25 am
For those of you using water to clean, do you have any special way of drying the chain?
PostPosted: Sun Jun 26, 2016 2:57 am
I dry my chain with compressed air.
It's all downhill from here, except for the uphills.
PostPosted: Sun Jun 26, 2016 3:06 am
I wonder if my wife would have a problem with me using her hair dryer? Has anyone tried this?
There are no new unread posts for this topic. Edco Monobloc : chain skip after new chain install on only 1 cog
Delorre
25
3103
Sat Jan 06, 2018 9:49 pm
spud View the latest post
There are no new unread posts for this topic. Di2 chain
Timmy269
27
1743
Fri Oct 06, 2017 8:20 am
Ritxis View the latest post
There are no new unread posts for this topic. Attachment(s) sorry, another one of these... chain too short?
octave
10
1115
Thu Jun 22, 2017 6:30 am
2lo8 View the latest post
There are no new unread posts for this topic. Di2 chain slap
thebadgerboy1982
Mon Apr 17, 2017 12:55 pm
nycebo View the latest post
There are no new unread posts for this topic. How dirty does your chain get?
Boshk
25
1459
Sun Oct 29, 2017 12:18 am
CrankAddictsRich View the latest post
Users browsing this forum: Baidu [Spider], Google [Bot], Google Adsense [Bot], sub7kg and 27 guests
