Lightest QR that actually works well?
- Moderator
I had one of my Far and Near ones snap at the cam/lever point the other day. Glad there were extra wheels in the support van. I like my skewers snug but didn't think I was being excessive with them.
Using Tapatalk
Oops. Did it snap while operating the lever or during a ride?
Did the titanium rod fail or the aluminum parts?
How old were they?
Thanks!
How old were they?
Thanks!
evan326 wrote:I just got a set of Zipp Ti Aero skewers at 69.2g for the set. So far so good.
Those are my favorite skewers but they aren't the newer "aero" model. I have an aero set as well and they work just as well except they don't have the nice flat lever and hurt your hand more.
I agree with others on the Zipps. They are a quality, reasonably light weight skewer. I figure that Zipp wouldn't put crappy skewers on their $2000+ wheels.
AJS914 wrote:evan326 wrote:I just got a set of Zipp Ti Aero skewers at 69.2g for the set. So far so good.
Agreed on the Zipps, too. I got the Ti Aero, they have the flat handle. I've also tried the Tune's and the KCNC. I didn't like the locking action of the Tune's at all. The locking action on the KCNC is better, but the Zipps feel really secure, are reasonably well priced (especially compared to the Tune's), and light. At least, light enough for the Zipps. Not quite as light as the other two but the locking action and sense of security is so much better, to me it's worth it.
- Moderator
Marin wrote:Oops. Did it snap while operating the lever or during a ride?
How old were they?
Thanks!
Tightening the skewer after a flat, the aluminum arm broke at the machining step.
Using Tapatalk
Nefarious86 wrote:Marin wrote:Oops. Did it snap while operating the lever or during a ride?
How old were they?
Thanks!
Thanks - so it failed in a way that wouldn't have created a risk during riding I guess!
Unfortunately I'm now using the heavy Campy QRs with steel rods. The Aliens 4 cannot grip the front wheel tightly such that my front wheels is constantly going off-center. The Campy QRs have no such issue and the front wheel remains on-center. I guess there's a good reason why Shimano and Campy don't attempt to save weight on QRs.
pdlpsher1 wrote:The Aliens 4 cannot grip the front wheel tightly such that my front wheels is constantly going off-center.
Ha, I knew it wasn't just me having this issue.
What wheels are you guys using? I would think wheel slippage has just as much to do with locknuts/endcaps as it does with the skewer.
[14lb(6.35kg) of no carbon fiber]
[2lo8.wordpress.com]
- in the industry
- Contact:
Carbon ti skewers (39g) work well. I also have a set of token shark quick releases that work just fine (47g). I also have a set of ebay no name skewer (37g) that work well. Maybe i am lucky with skewers.
I know this sounds weird but the heavy QRs with steel rods and internal cams provide a stiffer and more solid feeling to the bike. I know it's a lot of weight penalty but I really do feel I can put the power down more effectively especially when I'm climbing out of the saddle. To each and his own...
TheDarkInstall wrote:pdlpsher1 wrote:The Aliens 4 cannot grip the front wheel tightly such that my front wheels is constantly going off-center.
Yup. I saw your video and I have the exact same issue. A slightest bump on the wheel knocks it off-center. Even if I don't touch the wheel it goes off-center after a ride. I weigh 62kg and I don't sprint.
Strangely I have a set of generic QRs with titanium rods and external cams on my tandem with no issues. So maybe the fork and wheel has something to do with it. The titanium rods on the tandem are not butted like those on the Aliens 4.
Butting might have some effect on retention, although I can't quantify how much. Even if you get the same static clamp force with both, the butted one should elongate more for the same forces acting on it, or require less force to elongate the same amount.
For the same diameter rod, a steel rod in theory would have twice the clamping force than the titanium counterpart. Since the Aliens 4 front rod is butted to an extremely thin diameter, the difference would be even greater. Funny how the modulus of elasticity is exactly correlated to weight. Twice the modules of elasticity means twice the weight.
