It is currently Tue Jan 23, 2018 1:41 am
Post new topic  Reply to topic  [ 53 posts ]  Go to page 1 2 3 4 Next
 Post subject: EE-brakes
PostPosted: Fri Jun 17, 2016 11:00 am
I'm thinking of biuying EE brakes.
Where can I get them in Europe?
Second question for the guys who have them, is there brakepower at the same level of Dura-Ace and Sram Red calipers?
I live in Belgium, where it's dirty on the road, will they keep on working fine?
 Post subject: Re: EE-brakes
PostPosted: Fri Jun 17, 2016 11:13 am
Starbike.com!
Trek Mad-one 7 Series team colours http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=115500&start=15
Fuji SL 1.1 http://weightweenies.starbike.com/forum/viewtopic.php?f=10&t=140134&hilit=Fuji
PostPosted: Fri Jun 17, 2016 12:26 pm
I use EE Brakes with Dura Ace 9000 and they work really well, have good modulation and have never left me wanting for braking power even with my Edge 1.38's which weren't renowned for good braking.
It is really easy to swap pads and they work well with wider rims.
The only downside is that they are a bit harder to keep clean.
There is a recently upgraded option with a few nice tweaks.
Parlee Z5, Trek Madone, Jonesman Custom
Ozrider - Western Australia
PostPosted: Fri Jun 17, 2016 12:52 pm
everything bit that Ozrider says. when set up properly...they brake just as well as DA brakes. i use them with DA Di2 and have a set on Campy SR11. no issues with either group.
i use a brush to clean them...since there are generally more exposed areas for dirt to get into.
- AX Lightness Vial EVO D + DA9070 + Enve SES 3.4 carbon hubs
- Parlee ESX + DA9070 + THM SRM PM + Enve SES 6.7 CK hubs
- Independent Fabrication Ti FLW + Campy SR11 + Enve 3.4 CK hubs
PostPosted: Sat Jun 18, 2016 8:33 pm
Yeh just got some new brakes in stock...
http://www.starbike.com/en/ee-cycle-works-eebrake/
Thanks Craig from ee cycle works for those awesome brakes...
Gesendet von meinem MotoG3 mit Tapatalk
My bike:
http://www.starbike.com/galleries/?id=50
PostPosted: Sat Jun 18, 2016 9:13 pm
do sellers in EU have the newer version - different centring nut + different cable adjuster ?
Starbike & ubky both have images of the older version.
I know FWB in US has newer version but want to avoid US duty coming into EU - and would prefer the newer centring allen key adjuster.
PostPosted: Sat Jun 18, 2016 10:46 pm
For a brakeset thats almost half the weight of the OE stuff, the EE brakes works pretty good. They have sufficient stopping power but I have found that it's not as good as Dura Ace or Red Aerolink brakes. The amount of lever force required to slow down the bike on a down hill is far greater with the EE compared to DA or Red...and yes, I have everything properly set up.
____o
_`\<,_
PostPosted: Sun Jun 19, 2016 3:08 am
Agree with the above post, but keep in mind that the lack of initial bite might actually lead to greater overall modulation.
PostPosted: Sun Jun 19, 2016 6:15 am
I think it depends on you how you set them up, I could not tell a difference between my EE's and my DA9000 brakes and at 220lbs I can always tell when a brake is weak.
PostPosted: Sun Jun 19, 2016 9:29 pm
Also http://www.ubyk.co.uk/eebrake-by-ee-cyc ... 2016/21232, which is where I got mine.
PostPosted: Sun Jun 19, 2016 10:40 pm
Way better than Red Aerolinks
Gramz
Failed Custom Bike
PostPosted: Sun Jun 19, 2016 11:06 pm
Has anyone tried the new EE direct mount brakes? While I love my Dura Ace direct mount brakes they are quite a bit of a boat anchor :D
PostPosted: Mon Jun 20, 2016 1:37 am
the new arch is so much nicer than the previous version. i have the first DM that Craig produced. thinking about upgrading only the front.
PostPosted: Mon Jun 20, 2016 3:56 am
I just installed a set of EE's, not the newest version but the one prior to that (2015's, I guess).
I'm really impressed with them. I came from Campag Super Record 11 brakes (dual pivot front + single pivot rear). The ee's feel very strange at first and when you're setting them up. They feel so soft, the effort of clamping the lever is so minimal compared to the SR calipers. So I was concerned that they wouldn't clamp well..
The modulation is certainly better, much easier to feather into full braking, less of an "all or nothing" feeling, to me at least. I feel that the max clamping power is slightly better than my SR brakes, but obviously that's entirely subjective. Perhaps its because I feel like I am putting less force into the levers. Needless to say, I certainly don't feel that I lost a bit of stopping power in making the switch. For what its worth, I am a small guy (~60kg) and likely am not as hard on brakes as others may be and I feel I have plenty of stopping power. As far as rim brakes go, in the dry, I don't think I could stop any faster without breaking traction at the tire.
2015 Cervelo R5 (6.3kg)
Strava
PostPosted: Mon Jun 20, 2016 4:22 am
Agree with KWalker - used Red Aerolinks for a little under a year before swapping to Ee on a new build. For me they offer much better initial bite and way better modulation. I had to apply a lot of lever force to get the same bite from the Aerolinks. I have not used DuraAce but the Ee's have the same amount of power as Ultegra but way better modulation.
They blow other lightweight options that I have used out of the water, which is pretty much what everyone always says about them.
There are no new unread posts for this topic. These Lightweight brakes?
PLuKE
7
1425
Mon Aug 07, 2017 8:42 pm
kulivontot View the latest post
There are no new unread posts for this topic. Magura brakes & DI2
Thepants
Wed Aug 23, 2017 10:59 am
Thepants View the latest post
There are no new unread posts for this topic. EE brakes for Supersix Evo
logy
10
1101
Sat Jul 15, 2017 9:59 am
sungod View the latest post
There are no new unread posts for this topic. ee brakes + powercordz
sungod
9
1382
Sun Mar 12, 2017 2:03 pm
mdeth1313 View the latest post
There are no new unread posts for this topic. Enve 3.4 SES and Zero Gravity Brakes
markcp
Tue May 23, 2017 4:15 pm
Beaver View the latest post
Users browsing this forum: Bing [Bot], cycleboyco, dricked, Hexsense, Majestic-12 [Bot] and 34 guests
