So previously I rode sidis, but I could never get the cleats back enough. I drilled the soles for a more rearward cleat placement (not even close to mid foot, just maybe 3/4 cm behind the stock holes). This worked great, but the cleats hung off the side of the sole too much. I recently bought shimano r321s because the soles allowed for extra rearward placement of the cleats without drilling, and they are great in terms of cleat placement but they're not a perfect fit (and yes I had them heat molded).
My question is: I noticed lake soles have similar adjustability (the nuts move in the soles); can anyone tell me if the cleats can be pushed back as much as on the shimano shoes? I know that's a pretty specific question but...doesn't hurt to ask. Thanks in advance.
Lake shoes--how far back can you get the cleats?
I'm sorry this will only be tangentially helpful. I have Lake 402s with the speed play 4 hole sole. On those I have a considerable amount of fore-aft cleat adjustment, more than my old (3 hole) Spec and more than I can imagine needing unless someone wanted a true mid foot position. However thats the 4 hole sole. Great shoes though.
Ovalier, I happen to have some new Shimano R321's and Lake CX237's handy and without the cleats mounted, so I took a photo of them side-by-side, with the soles facing up (and threw in a pair of S-Works Sub 6 as well). Note that these are all *Wide* sizes (SW 6 in 44; R321 in 43; and CX237 in 43.5). The lengths are slightly different, but seem to be within +/- 5mm of each other, especially when you take into account that the R321's have a pretty substantial "bumper" on the toe which adds length. So, from a quick eyeball comparison, I think the Shimano gives slightly more room for aft cleat placement, maybe 5-10mm, but they are all in roughly the same ballpark of fore-aft options. For substantially greater rearward placement, you'd need to drill.
JohnHinMD wrote:Ovalier, I happen to have some new Shimano R321's and Lake CX237's handy and without the cleats mounted, so I took a photo of them side-by-side, with the soles facing up (and threw in a pair of S-Works Sub 6 as well). Note that these are all *Wide* sizes (SW 6 in 44; R321 in 43; and CX237 in 43.5). The lengths are slightly different, but seem to be within +/- 5mm of each other, especially when you take into account that the R321's have a pretty substantial "bumper" on the toe which adds length. So, from a quick eyeball comparison, I think the Shimano gives slightly more room for aft cleat placement, maybe 5-10mm, but they are all in roughly the same ballpark of fore-aft options. For substantially greater rearward placement, you'd need to drill.
How do you move those plastic inserts on the cleats for Shimano shoes?
I've been wanting to move my cleats further back and I cannot figure this out
Thanks
