Shifting woes
I have a 2015 cervelo s3 with super record 11 sp. 52/36 rotor crank. It shifts fine in the big ring but not so good in the small ring. I can't figure it out. New chain and cassette. I checked the hanger alignment also.
I am pretty sure the chain is right length but I may take a link out and see if that helps.
Anyone have another idea?
How old are the cables?
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Have you got adequate tension on the RD? Had a similar issue on a SRAM rd because I didn't have the b-tension screw set correctly.
I write the weightweenies blog, hope you like it
Disclosure: I'm sponsored by Velocite, but I do give my honest opinion about them (I'm endorsed to race their bikes, not say nice things about them)
Campy chain and cassette? Versus a mix of brands? Chain length set as per campy guidelines... When in small/small a 10-15mm gap between chain and upper pulley?
Gregorio wrote:Found the problem while removing the der to check hanger alignment again. one of the screws was loose on the hanger allowing it to wiggle back and forth.
thanks weenies
threadlocker is your friend on those tiny hanger bolts..don't want to over tighten them but don't want them going loose either.
