Colnago C60 rear brake rub. Stiffer wheels?
RedRacer
by RedRacer
My set-up is a Colnago C60 58s with DA 9000 brakes, SwissStop Black Price pads and Bontrager Aeolus 5 TLR Clinchers but I am getting bad brake rub/drag when climbing out of the saddle or sprinting.
I previously had the Bontrager cork pads installed and I think they masked the problem because they are so quiet and not at all grabby but with the SwissStop pads I can hear and feel the drag, especially when climbing out of the saddle on inclines greater than ~8%. I have the rear brake adjusted so loose that the lever almost contacts the bars before I get full stopping power. I have also tried three different rear QR skewers just to make sure that isn't the problem.
At this point I think it must either be a soft frame (doubtful!) or a wheel build that just isn't well-suited to this combination of parts and my 80kg.
If this problem is caused by the wheels what are the stiffest sub-1600g 50mm clinchers out there? Probably Lightweight but I am hoping for something a bit less costly.
beeatnik
by beeatnik
Definitely the wheelz. My rear 24H Archetype rubs on my C59. No rub with my Boras.
beeatnik
by beeatnik
Opposite load = top of wheel, between pads
RedRacer
by RedRacer
huck*this wrote:Re-tension wheels?
Maybe :noidea: To what tension?
eric
by eric
Unless the spokes are so loose that they go slack there's no real difference in deflection with spoke tension. See Damon Rinard's wheel tests.
The Bontrager wheels I have seen have a fairly narrow NDS flange spacing. That makes for less unequal spoke tension right/left but makes a flexier wheel. Ways to make a wheel stiffer-
-more spokes
-wider flange spacing
-stiffer larger cross section spokes
-stiffer (larger cross section) rim
One thing I have noticed with out of the saddle climbing is that my pedalling style and how much I rock the bike side to side makes a difference in the amount of brake rub I get. Probably not someting you want to hear (it's not for me!) but you could modify your out of the saddle style...
pdlpsher1
by pdlpsher1
Do you have another bike where you could use to see if it rubs with the same wheels? Could there be a defect or crack in the frame that's not visible with the naked eye?
RedRacer
by RedRacer
eric wrote:One thing I have noticed with out of the saddle climbing is that my pedalling style and how much I rock the bike side to side makes a difference in the amount of brake rub I get. Probably not someting you want to hear (it's not for me!) but you could modify your out of the saddle style...
Valid point but I think my out-of-the-saddle technique is quite smooth and this brake rub problem hasn't happened on my last five road bikes so I think it is something about the C60 / Bontrager / DA 9000 combo that isn't working...
XCProMD
by XCProMD
Check the quick release first. Most of the times that's the problem
Skickat från min iPhone med Tapatalk
RedRacer
by RedRacer
XCProMD wrote:Check the quick release first. Most of the times that's the problem
I run my QRs very tight and have tried three different ones (Ti, Ti and heavy steel) with no change :(
jimborello
by jimborello
I had the exactly same problem in an AX Vial Evo with Ciamillo micro G brakes and an enve 6.7 wheelset. I switched the wheels to Bora Ultras and problem solved.
