Uncomfortable saddle? Modify your bibs.
donald
by donald
I have a tune saddle on my rain bike that does not flex and doesn't fit me as well as the ones on my uber light bikes. For the last five years I have used a piece of neoprene in a few of my cycling bibs to use when I am on my rain bike. With the extra neoprene it is comfortable. I stretch the bibs on a round top stool using a quality fabric glue at the front and back only, then place a few heavy books on it; in a few hours its done. It holds up very well, no problems. One can always sew a little too. On my MTB saddle I glued just a little neoprene right on the carbon saddle.
mimason
by mimason
I guess its better than buying maxi-pads. Or get a saddle that works.
donald
by donald
I had modified this saddle to make it even lighter and so I don't think I could sell it or would not want to sell it. I just went with the extra padding; it really works well!
BRM
by BRM
Extra padding in your bibs??
If I were you I would go for butt implants a la Kim Kardashian. :P
kode54
by kode54
you can buy some boxers with pads in them... Rapha used to sell some boxers with padding in them. you wear them under regular shorts. you can probably use some of those under your regular bib shorts to achieve the same effect.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
vejnemojnen
by vejnemojnen
so-.-
how much weight did those pads added to the bibs? :)
