ww hanger alignment tool
- Frankie - B
- Admin - In the industry
Back to the OP's question please.
A carbon rod with a possibility to attach it to the hanger. (i do prefer the old stool method of screwing it in the hanger) and a tape measure will probably do. sounds like a cool tool.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!'Tape was made to wrap your GF's gifts, NOT hold a freakin tire on.'
It is not small in lenght but will not weight too much. It's cheap and effective.
Gear Hanger / Drop Alignment fix ( without buying expensive tools )
https://www.youtube.com/watch?v=WS2vd8N1Vos
That is a neat find BRM! I like the idea of taking the wheel out of the equation entirely, at least for shop usage. It has always seemed to add a degree of imprecision to me, and if you are already taking the Rear D off the bike, then it's nothing to take the wheel off too.
The above may not work if your derailleur hanger moves when you clamp your quick release.
A cheap home-mechanic trick I learned is to take an old wheel with a threaded axle. Remove the rear derailleur and screw the axle end into the hanger where the derailleur goes. Now you have another wheel parallel to your installed wheel. Take a tape measure and check the distance all the way around. Obviously, the distance should be the same.
@ AJS914
This topic is about a portable derailleurhanger allignment tool.
And yes in some cases the tension of the quickrelease matters.
Maybe that can be solved by making a tube with the lenght of the hub width, shove it over the threaded rod,
and then putting some tension on it by fastening the nuts.
*btw you need rods that are perfectly straight, so best is to choose rods that are made of good material
If you are on a group ride, you could potentially borrow someone's wheel to align your hanger, even on the road.
Do you just like to be pedantic? I was just threw out this tiny bit of knowledge because this method saved me from buying a $100 tool and I've used it dozens of times now and it works really well. Rather than debating with me you could just ignore my post if you didn't find it useful. Feel free of bring your theaded rod derailleur hanger alignment tool on every ride. The method you posted wasn't quite portable either.
All you need is a key to remove the rear derailleur. Remove quick release, thread in wheel by hand. Measure distance with anything (your hand, a stick from the side of the road, use the skewer). You don't need a tape measure. You just want the same distance all the way around. Pretend you are MacGyver.
AJS914 wrote:The above may not work if your derailleur hanger moves when you clamp your quick release.
I dunno - now you've got 2 wheels and that could introduce an error.
One wheel doesn't as you should use the rim where the valve is - turning the valve to the point you are checking. That removes any error from an out of true wheel because you aren't measuring just comparing to the same point on the rim.
I suppose you could rotate both wheels but you've still got a parallax error possibility.
I'm left handed, if that matters.
finally got around to it...
so far it is 104.7g, i may make some changes and still need to trim it a bit, i expect it to end up < 100g, compared to a 'real' adjuster i think i met my ww objective
edit: shortened the slider, now 99.5g
main shaft is 25mm carbon fibre angle, 2mm thickness
the cf angle is very stiff, i did some calculations before selection, the deflection at the level of force needed to adjust a hanger is tiny (it is less stiff when axial twisting force is applied, but that force isn't needed to adjust a hanger)
at the pivot end of the shaft, i bonded another section of angle to it, this is to make it tougher at the point where applied adjustment force is highest
the mounting point/pivot is 8mm stainless steel tube 1.5mm wall thickness, i tapped an m6 thread in it, a high tensile bolt connects it to the shaft - i may add a washer each side to avoid crushing forces on the cf at the edges of the tube and bolt head
why 8mm? the hole in an etap rear mech pivot is 8mm and about 12.5mm deep, the steel tube is a snug play-free fit, so the tool doesn't need to be bolted on, just slide in and adjust, very quick, no other tool needed - my original idea had been to use a bolt through the rd pivot, but the discovery that the 8mm tube worked so well meant i could simplify things
the tube is just long enough to allow the tool to be rotated without catching on the rear mech body
the sliding pointer for checking alignment is a piece of spoke, it has a spring loaded clamp on one end to set the 'depth', allowing it to be slid out as the tool is rotated then back in to stop at the depth set by the clamp
to allow positioning the pointer at the brake track, it is carried on a cf slider made from the same material as the shaft, the pieces are bonded together
the slider is held to the shaft with an elastic band, maybe not pretty but it works well, on the side of the tool away from the bike you just drag the band up/down to move the slider
for packing, the pointer simply slides out and can be tucked under the elastic band
