Tune MAG 160 - bearing play adjustment
I have got a Tune MAG 160 hub (purchased 2006 or 2007) that has developed some play. I have got the TT08 tool set. I need to put in a spacer to remove the play. Could someone please explain what I need to do to get the end cap off (drive side or non-drive side?). Any help would be much appreciated as I do not want to ruin the hub.
- Frankie - B
- Admin - In the industry
It is probably not what you are looking for, on my tune mag 180 I had to use two 5mm allen keys to unscrew the cap that sits over the axle and keeps the free hub body on the axle. when it was undone I had to pull with all my force (or wiggle) on the body to make it come loose.
If you want to see 'meh' content of me and my bike you can follow my life in pictures here!'Tape was made to wrap your GF's gifts, NOT hold a freakin tire on.'
