SRAM Etap blips
eliflap-scalpel
by eliflap-scalpel
i need to know if :
can I use the Blip Box + Blips and only rear Etap derailleur ?
in a 1x11 setup without Sram Etap levers
does the system work ?
http://eliflap.it/
Stuartclark1977
by Stuartclark1977
just ordered etap aero group (wiggle uk), i'll hook up that config. when it gets delivered and let you know!
____________________________________________________________________________
Firefly FF050
Scott Plasma 5 eTap
Scott Scale RC 900
eliflap-scalpel
by eliflap-scalpel
many thanks
http://eliflap.it/
oldnslow2
by oldnslow2
The RD is the master, so I imagine that it should work with no FD.
Stuartclark1977
by Stuartclark1977
So - I connected rear mech to blip box wirelessly and plugged two blips in. Didn't try to connect the front mech. Read mech shifts up and down and pressing both blips does nothing. Ie it did not self combust and the rear mech still works fine in both directions.
1*11 definitely possible via blips/blip box
Firefly FF050
Scott Plasma 5 eTap
Scott Scale RC 900
eliflap-scalpel
by eliflap-scalpel
great job, stuart
http://eliflap.it/
Stuartclark1977
by Stuartclark1977
scales to 0.5g accuracy only:
rear mech no battery: 215.5g
battery: 24g
fr mech no battery: 136.5g
4*blip 600mm cable: 38g (9.5g average each)
self adhesive flat blip box mount: 9.5g
blip box: 31g
Firefly FF050
Scott Plasma 5 eTap
Scott Scale RC 900
BmanX
by BmanX
This is great news. So you can do a fair bit with the eTap. For my Tri bike I could run CLIC's in the aerobars and then BLIP's down by the brake levers, please the blip box on my TriRig stem and just run a rear derailleur.
For a 1 X 11 road set up you could run a fairly simple 1 X 11 set up using blips, blip box and RD. It would not be expensive if you bought some S-900 levers and you could put the blip under the hoods. Cheaper set up but the only issue is the blip box BUT you could use a over/under mount for the garmin with the garmin above and the blip box under. A bit chunky but could be done.
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
Stuartclark1977
by Stuartclark1977
I'm currently contemplating, cutting the blip cable, joining the blips from the brake lever and extensions onto one cable each and extending it, running through the down tube and up the seat tube so that the box can be mounted under my saddle on the TT bike...just haven't plucked up the courage.
Firefly FF050
Scott Plasma 5 eTap
Scott Scale RC 900
woodnat1
by woodnat1
Resurrecting an old thread here, but I'm also contemplating extending the blip wires. Has anyone had success with this?
