Question for Kinesis Racelight owners
addictR1
by addictR1
i'm looking at a 48cm Kinesis Racelight T2 V3 Frame and have a couple questions for Kinesis Racelight owners:
1) i see they have their own brand of fork.. but wondering if you would recommend on using that or should i go with a different front fork?
2) what's the weight of the frame?
3) how's the ride quality? is the BB section stiff enough for climbing without feeling like a spring?
4) how's this compared to a CAAD10 or CAAD12?
thanks in advance.
Ravnsnaes
by Ravnsnaes
The Kinesis T2 is basically what most would consider a winter og wet weather frame, that is intended for mudguards and 57mm long-reach brakes. The T2 is in no way inetended to compete with high-end aluminium frames like the CAAD 10 or 12.
Bondurant
by Bondurant
I have a tk3 so take my answers with a pinch of salt but kinesis tend if anything to overbuild their frames so I'd say flex in the bb is unlikely and likewise it is likely to be on the porky side in terms of weight.
I believe geo between t2 and tk3 is the same or similar, mine is good to ride.
Are you talking about the Tracer fork? If so, it's a good option. Solid and tracks well.
Sent from my SM-G920F using Tapatalk
addictR1
by addictR1
Ravnsnaes: yea i know.. this built won't be a WW build.. rather an everyday ride/commuter
Bondurant: thanks, i was also reading up on the crosslight model and that was 2.2Kg for frame + fork for XL. so since i'm looking at 48cm, should be much lighter i hope.
mattr
by mattr
The forks are actually pretty nice, you'd have to drop a significant amount of cash to get a better equivalent. Maybe upgrade to a better kinesis one. Full carbon?
Both mine (tk) and my wives (t) are plenty stiff and quite nice to ride. Mines about 10 and a bit kilos ready to ride including guards. Got no worries riding it in exactly the same manner as my race bike.
Mockenrue
by Mockenrue
Can you stretch to the TK3/4S? I replaced my T2 with one and it's definitely worth the extra. 300g lighter and improved ride quality with a stiffer front end.
addictR1
by addictR1
Mockenrue: i wouldn't mind going for the 4S model.. but i've only seen the 4S with disc.. but i don't want disc. anywhere else sells the gray color one?
or how about Aithein? i see it's a bit more...
Mockenrue
by Mockenrue
I don't know where you are but there are plenty of places selling the standard 4S in the UK, e.g. here (product code RZH5594.)
addictR1
by addictR1
Mockenrue: thanks!
Tenlegs
by Tenlegs
Kinesis Racelight fork recall
viewtopic.php?f=14&t=139627
