Damage to Zipp 303 Brake Track
justonwo
by justonwo
Hi guys,
I'm new to the forum and hoping to get some opinions on the damage done to my Zipp 303. I believe I hit a pot hole and scraped the brake track, as there are also scrape marks on the sidewall of the tire. The damage doesn't seem that significant, but I'm curious if the wheel is rideable as-is, if it needs to be fixed, or if (hopefully not) it would need to be replaced. Thoughts would be appreciated.
Juston
2020 F12 AXS Red (Zipp 353)
2021 S-Works Aethos Di2 9200 (Alpinist CLX II)
2006 Cervelo Soloist
2021 S-Works Epic
2024 Topstone Lab71 (Force/XX1, Terra CLX II)
Retired: 2014 and 2020 S-Works Roubaix
2020 Canyon Ultimate
2018 S-Works Camber
mr_tim
by mr_tim
how about examining inside face (given it looks to be a clincher) ?
what sort of speed / force were you carrying into the impact ?
justonwo
by justonwo
mr_tim wrote:how about examining inside face (given it looks to be a clincher) ?
The inside is fine. The damage appears to be to the resin surface and not the structure. I don't think the force was that significant since I don't even know what part of my ride it happened on. I only noticed it after I was finished riding. My main concern is whether the braking surface around that area will deteriorate over time and the damage will propagate.
2021 S-Works Epic
2018 S-Works Camber
oldnslow2
by oldnslow2
Have you called Zipp?
I've found them easy to get on the phone and talk to.
4ibanez
by 4ibanez
I'd still ride 'em. Looks like a scuff to the surface, and no other signs of damage through the wall. Take them on an easy ride to test them out and get your confidence back. Maybe a carbon repairer can add some resin over the rough part (your braking may suffer).
