Carbon Rim brake blocks - which is best
Which Carbon brake pads do you use?
Swiss Stop Yellow
12%
Cork
14%
Reynolds Blue
9
21%
Other
23
53%
Total votes: 43
dmulligan
by dmulligan
I have asked this question before because the manufacturer of the rims I have don't make a recommendation. I'm using Light Bicycle rims with basalt brake tracks.
For me, temperature is a very very close second priority to stopping power. Actually given that all brake pads stop, maybe temperature is first. I've never had a heat related failure, or a failure of any kind, but I still worry about heat build up.
Reynolds Blue are the only pads I've tried so far but even they can impart a fair amount of heat in a short time given the right circumstances. There is a 1km 9 to 10% grade descent with tight switch backs nearby. I don't Ride my brakes down it unless there are cars adhering to the 30km/h speed limit. On a hot day after following a very show car my brake tracks were about too hot to touch. How hot were the rims internally?
Sent from my Oneplus One using Tapatalk
Bluecoupe
by Bluecoupe
I use Reynolds blue as I don't want to void warranty.
eric
by eric
Light-Bicycle doesn't make any brake pad recommendations at all? I'm a bit surprised.
Based on my experience with basalt brake tracks on FarSports rims the blue Reynolds pads are about as good as any. Black Prince carbon might be a little better. Bontrager cork are also good but are super expensive.
I also avoid super steep descents with tight turns (or slow cars) when on carbon clinchers. Since I live on a road like that, that means I often use aluminium rims.
TwiggyTN
by TwiggyTN
For dry conditions I think cork is best by far, in the wet, Campy red or Black Prince. I have 2008 Zipps, some Boyd, Eastons, and an old Gigantex set.
Sent from my GT-P5113 using Tapatalk
velomane
by velomane
Bluecoupe wrote:I use Reynolds blue as I don't want to void warranty.
Same here, on a pair of Assaults.
perwjensen
by perwjensen
Swiss Stop Black Prince on Farsports rims. Works great.
joepac
by joepac
swissstop black prince
