Carbon Rim brake blocks - which is best
Which Carbon brake pads do you use?
Swiss Stop Yellow
12%
Cork
14%
Reynolds Blue
9
21%
Other
23
53%
Total votes: 43
oreoboreo
by oreoboreo
I had to mark other
.. Swiss stop black prince. On the other hand make sure you use what your rim manufacturer suggest
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
GT56
by GT56
you need to tell us what wheels you will be using
tommasini
by tommasini
Yes rim manufacturers can be sticky about saying only use their pads.
That said, when the red/black Campy pads came out a couple of years ago you could see a number of pro tour teams running them on various brands of wheels........
MoreRideTime
by MoreRideTime
I think the best choice are whatever the manufacturer recommends; that way you won't void the any warranty.
Rick
by Rick
I don't have wide enough experience to claim they are "the best", but Reynolds Blue work very well (and I am using them with Reynolds Rims).
nickf
by nickf
With my bontrager wheels i like the cork pads. Black prince pads are the only other pad trek recommends to not void warranty and they were terrible.
benhama
by benhama
I use Swissstop Black Prince on my Bontrager Aeolus D3 5's and am very happy with them. They work great in the wet or dry.
Geoff
by Geoff
In the dry, cork is still the best.
eric
by eric
Different rims work best with different pads. On some rims cork is great, on others it's terrible and will void the warranty.
However I can say that SwissStop Yellows should never be used- there are other pads (I.e. their Black pads) that work better on the same types of rims. The Yellows put more heat into rims. I know a Trek dealer who regularly sees Bontrager rims ruined by Yellows.
Rim makers will not honor the warranty on rims ruined by using the wrong pads.
prendrefeu
by prendrefeu
I've had great experience using the ZIPP Tangente Platinum Pro (grey) pads on my FarSports rims. Just a bit better than the Reynolds Blue, which were already pretty darn good.
fh8425
by fh8425
for me is the campag red/black pads on my campag carbon rims ... works great !!
ifrit
by ifrit
I'm using Corima red cork pads and it works great and price is reasonable for me.
8) Condor Leggero 2015 Mavic Team :evil:
dolophonic
by dolophonic
Zipp grey pads get another vote from me..
About to try some lightweight/ swiss stop will let you know after a few kms
duvivr6
by duvivr6
I went from Swisstop Yellows to Black Price on Chinese carbon and they are certainly better.
I had a set of blue pads that worked well also, but I am liking the black Prince.
fogman
by fogman
The best carbon rim brake pads are the ones that came with your wheelset. I am using the Campagnolo red pads on my Bora rims. Most companies will void your warranty if you use a different brake pad. I believe the companies have tested their brake pad/rim combination to give the best braking performance and heat dissipation. You don't want to put more heat into the rim than necessary by using an unauthorized brake pad, especially on carbon clinchers.
It's all downhill from here, except for the uphills.
