DLC coated chains - casette wear
Hi there. I've been thinking about getting the KMC X11-SL, but I wonder if anybody knows if this chain wears out cassettes faster than other finishes? I mean, the finish is supposedly harder than treatments on other chains, but the finish also supposedly reduce friction. The harder finish should equal more wear on the cassette, while the reduced finish on the other hand, should increase cassette life. Does anyone know if the sum of these two factors result in longer or shorter cassette life? If you do know anything, is it based on facts/reaserch, or is it just based on opinions?
I'll be glad to hear about your thoughts/experiences if you have any. Thanks!
I have a black DLC KMC and haven't noticed anything out of the usual. Have been running it for 300km so far on a used XX1 cassette.
The primary cause of cassette wear is the way cog teeth deal with extremely uneven loads from a stretched (worn) chain, until the cogs wear down to match the pitch of the stretched chain and loads become more equally distributed again. So if DLC prevents chain stretch, it's reducing cassette wear.
[14lb(6.35kg) of no carbon fiber]
[2lo8.wordpress.com]
It doesn't though, the rivets and inside of the rollers where the wear happens aren't coated.
I guess the wear is quite the same then. As long as it doesn't make things worse, I'm happy really. Another question, just out of curiousity; do you think a DLC coated cassette would last longer than the ordinary coatings (I know there's quite a few)?
This chain is not worth the money. The coating proberbly not real DLC and negative reviews like here says enough to me >
http://www.chainreactioncycles.com/nl/e ... prod120628
BRM wrote:This chain is not worth the money. The coating proberbly not real DLC and negative reviews like here says enough to me >
I don't really expect any performance boost with this chain over the Ti-nitride one, but I wouldn't want it to work less good either, of course. The real reason I want this chain is because of the black finish. So if it works as good as the TiN one, I'll probably get it eventually. Another option is the black TiN chain from Yaban of course. But it is a little bit heavier than the KMC according to r-2bike.
UpFromOne wrote:All DLC is, is a spray-on finish to the sideplates prior to assembly. A gimmick that adds nothing to the performance of the chain.
This is far from the truth. DLC is not a spray-on finish. It might be a gimmick for bicycle chain applications though.
As this thread pointed out, the DLC on the side plates does almost nothing, as the steel bushings still do the actual contact work. I can understand the issue of the side plates rubbing each other as the chain bends, but this is a small part of the overall friction generation of a chain system.
If you want a low friction chain, there are much better chains out there, such as the CeramicSpeed dipped ones.
Lube makes a huge difference rather than the build of the chain.
