SRM PC8 Strange KMs difference
Hallo everyone,
I have noticed that on my PC8 screen when I finish the ride, it displays a total number of the overall distance (like the picture below) But, when I upload the file to TP or Strava it shows a completely different overall distance. Did any of you experience the same? Or has an explanation why it occurs?
example fro today. on the PC8 screen it says 142,7KM on TP/Strava it says 138 KM that a big margin (4,7 km) :/ scary..
insta: @fbonde
TurboKoo wrote:Maybe you should check your wheel settings. Seems like difference between gps and wheel sensor setting.
Thanks for your replay Turbokoo. I'm not using ANT+ speed sensor at all. I only use GPS. I mean, the wheel size setting some alive, when you choose ANT+ sensor for speed.
insta: @fbonde
gps 'distance' depends to the calculation used to join the dots of the sample points - simple straight line interpolation will under report on any twisty/hilly course, fitting a curve takes more calculation but should be more accurate though steep climbs/descents still will introduce more error due
there's no one 'right' way to do this, so over a long course it'd be easy for different methods to arrive at significantly different answers
if you want accurate speed/distance, a wheel sensor (with accurate circumference measurement) is better than gps
sungod wrote:gps 'distance' depends to the calculation used to join the dots of the sample points - simple straight line interpolation will under report on any twisty/hilly course, fitting a curve takes more calculation but should be more accurate though steep climbs/descents still will introduce more error due
I agree, but surely we can agree on one thing, that a margin like this, is way above the "limit". I have never on my garmin or my Polar GPS watch experienced that high error on GPS points.
insta: @fbonde
but unless you *know* the calculation method used by each, you cannot know what the likely error bounds are, on the route involved it may be reasonable... if strava is attempting to apply a terrain database to calculate surface distance over gradient and the gps is using a 2d algorithm, they could give very difficult figures (both of which could be equally wrong)
if the garmin/polar use the same algorithm, they will show similar results, it doesn't mean they are any more accurate
it comes back to: if you care about accuracy, do not use gps, use a wheel sensor
sungod wrote:but unless you *know* the calculation method used by each, you cannot know what the likely error bounds are, on the route involved it may be reasonable... if strava is attempting to apply a terrain database to calculate surface distance over gradient and the gps is using a 2d algorithm, they could give very difficult figures (both of which could be equally wrong)
To be honest, it seams very strange, that the SRM device agent read one number, and SRMX read a completely different number. To me, thats not good at all if we are talking "Gold standard" like SRM. I dont reallt care about Strava or TP, its more the SRM software it self. Nothing is perfect iknow, but margins like this is simply unacceptable.
insta: @fbonde
fwiw i get an exact match between pc8/srmx/golden cheetah, i use a wheel sensor, if you are seeing a difference it does suggest the cause is in the gps data interpolation
if you want a definitive answer to any pc8/srmx discrepancy i think you need to contact srm support and ask about it
sungod wrote:fwiw i get an exact match between pc8/srmx/golden cheetah, i use a wheel sensor, if you are seeing a difference it does suggest the cause is in the gps data interpolation
Thanks for that information.
Is it possible to use a speed sensor for speed and distance, and let the GPS in the PC8 visualize the route afterwood ?
insta: @fbonde
fbonde wrote:sungod wrote:fwiw i get an exact match between pc8/srmx/golden cheetah, i use a wheel sensor, if you are seeing a difference it does suggest the cause is in the gps data interpolation
Yes, that is what we did.
toiyuet wrote:fbonde wrote:sungod wrote:fwiw i get an exact match between pc8/srmx/golden cheetah, i use a wheel sensor, if you are seeing a difference it does suggest the cause is in the gps data interpolation
Perfect - Any setting I should be aware of?
insta: @fbonde
it's easy to do in pc8 device agent, settings are in the bike profile...
once you've got the speed sensor, you pair it to the pc8 and set the wheel circumference (best to measure it, not rely on any default values), you also set speed to ant+ instead of gps, and save the config to the pc8
sungod wrote:it's easy to do in pc8 device agent, settings are in the bike profile...
Sounds perfect. So by setting the speed to ant+ dosent turn off the GPS automatically? if so, the "problem" is solved. How long time do you guys whait for the GPS signal ? I wait op to 7 minutes every single time.
insta: @fbonde
setting speed to ant+ only affects the speed/distance method, gps data is still recorded for position (unless you turn gps off completely)
i usually wait until the signal indicator shows 2-3 bars, just a minute or so if there is nothing tall nearby - though even with full signal i noticed the gps data can sometimes be off by 10-15 metres if there is heavy tree cover or similar obstruction on a route
