anyone know the torque spec for this?
addictR1
by addictR1
when trying to install my rotor QXL rings to my force22 crankarms, i had to remove these screws to gain access to torque down the 5th hidden bolt behind the drive-side crankarm.
currently i torqued it down to 10nm + blue loctite, but not sure if anyone knows the specific torque spec for these circled in red?
thanks.
pdlpsher1
by pdlpsher1
The proper way to install this ring is to get the special pressed-in nut for the hidden bolt. This way the hidden bolt can be installed without detaching the crank spider. Perhaps you could contact SRAM for the proper torque value.
pdlpsher1
by pdlpsher1
I recall now that you got a different bolt set on Amazon. I guess your method works but eventually you'll run into the same problem every time you change the ring.
addictR1
by addictR1
pdlpsher1: yup, i didn't get a press-in nut for the hidden bolt. contacted sram and just got the run around.
addictR1
by addictR1
Thanks kkibbler. Guess 10nm is a bit much then....
wheelsONfire
by wheelsONfire
I think Rotors spec is 7Nm.
Run 6Nm and use Loctite small (just one drop) one each bolt.
Do not soak them!!
http://www.amazon.com/Loctite-38653-Pur ... B0002KKTT0
I used this at my Buell motorcycle and it hinders bolts from coming off.
This motocycle use an old HD Evo Sportster engine.
This vibrates A-L-O-T so if Loctite 222 is sufficent for these bolts, they for sure will remain seated on a bike!
It also brakes the (Loctite) bond at 6-8Nm.
This is the only Loctite you should use at bolts for cycling.
Bikes:
Open *UP* (2016.04.14)
Valbrona
by Valbrona
pdlpsher1 wrote:The proper way to install this ring is to get the special pressed-in nut for the hidden bolt.
Go on then ... where do you get them from?
2lo8
by 2lo8
In general, if it's not something that's clamping onto something that can break, like a stem or a seat clamp does, you can usually just go by engineering spec sheets for a given thread size, as things will generally be engineered to standard engineering specifications.
[14lb(6.35kg) of no carbon fiber]
[2lo8.wordpress.com]
pdlpsher1
by pdlpsher1
I got mine from Quarq. And SRAM owns Quarq. I don't own a Force crank but I assume every Force crank with stock chainring comes with one? So if you buy a Force replacement chainring it should come with one. And SRAM should be able to supply the part individually.
HakeemT
by HakeemT
FWIW, when I swapped cranks on my Quarq PM, SRAM told me to use Loctite 638 (I ended up using 680) and torque those 3 bolts to 10nm.
addictR1
by addictR1
Ok finally got an official email back from SRAM
Torque spec for spider bolts is 8.9Nm.
Regards,
SRAM USA
www.sram.com
Service and Technical Documents:
www.sram.com/service
Learn more about The Power of Bicycles: www.worldbicyclerelief.org
pdlpsher1
by pdlpsher1
8.9Nm? I hope that's not a joke. Why not just round to 9Nm :-)
addictR1
by addictR1
pdlpsher1 wrote:8.9Nm? I hope that's not a joke. Why not just round to 9Nm :-)
lol.. i know huh? i just took that as a typo... when they meant 8, 9nm.
BRM
by BRM
Nm is the max force you can use before a bolt breaks
Mostimes the given torque is the MAXIMUM
Normally the given max torque is for dry bolts
When using a form of lube the used torque needs to decrease (Lubrication factor)
Probably 5-6 Nm would be more than enough
Steel bolts can bare more Nm than alu bolts
