Sram etap & 11-30 cassette
Marin
by Marin
The old non-Aeroglide won't even work with an 11-28 cassette without a lot of problems, it's specified as 11-26 max. For anything above 26, you need the new, Aeroglide 10 or 11 speed version anyway.
Eclat
by Eclat
I heard that it is usable, but not fitted perfectly.
mikey168
by mikey168
Slightly off-topic, but I use a SRAM short cage mechanical RD for my 11-32 cassette using Roadlink hanger extensions.
Works a treat, no issues with chain slack on the small/small combo, so long as you have the correct chain length for it (I tend to avoid cross chaining anyway even though it is perfectly safe so it's not an issue for me).
Best $40 I have ever spent on my bike.
richphoto
by richphoto
I just put a red 11-30 on my etap short cage and it works perfectly. No way a 32 would work though.
spdntrxi
by spdntrxi
I have an 11-30 on one wheelset with std eTAP RD.. no problems... from the position of the B screw.. a 32 might even fit, but I dont have a 32t cassette to try
2024 BMC TeamMachine R
2018 BMC TImeMachine Road
2002 Moots Compact-SL
2023 Pivot E-Vault
alcatraz
by alcatraz
I put a 36t on a red mechanical middle cage derailleur. Works well apart from a bit less precision on the small cogs. Shifting down on the small cogs needs a little help meaning you have to overshift a tiny bit to get smooth shifts.
I think people tend to see it a bit too black and white. It's not like that.
You sacrific shifting performance bit by bit going away from the particular derailleurs ideal cassette size.
A race bike would need a higher standard build but for cruising it works. That's my take.
/a
apricotwalnut
by apricotwalnut
Yes, it's working well.
don't need to change it to WIFLI.
