favorite grease to use?
i've been using Phil Wood Waterproof Grease for many years on my crankset. looking to find something lighter to use that won't provide so much friction.
current BB is SRAM, but that will soon be changed to Hawk Racking bb86 soon. so wanted to use some thing light for grease.
what's your favorite?
i've been using the Campy white grease. one of my favorites. used to use Phil Wood waterproof grease but was a little heavier. also use Baller's Nixfrixtion grease on other stuff like headsets.
- Factor Ostro VAM Disc
- Factor LS Disc
- Specialized Aethos Disc
- Sturdy Ti Allroad Disc
- Guru Praemio R Disc
- Factor LS Disc
- Stolichnaya
Extralite Alugrease is worth a look too.
kdawg wrote:I like the green Shimano stuff. Used to be branded Dura-Ace but I think it's just Shimano Premium grease now. Just the right consistency and it even smells nice.
I just got some of this stuff but I haven't tried it yet. Does anyone know how to use this stuff in a grease injector? I'd like to lube my Speedplay pedals with this grease.
- prendrefeu
- Contact:
Anti-sieze lube:
http://www.amazon.com/Permatex-80078-An ... B000FW7VGE
Can also be picked up from any auto-parts store, enough for more builds than you wallet can manage.
Use any anti-seize lube when 'exotic' metals are interfacing (Titanium, Aluminum, etc:.). The lube does not necessarily have to be metal-specific.
For carbon-to-carbon situations, Friction/Carbon lube.
Generally speaking, no need to buy the 'bike brand' stuff - it'll be an overpriced variation of what is available for far, far less at an auto parts store.
I would just use anti seize on titanium. Anything else is regular grease. I use finish line Teflon. Antiseize is tough stuff to clean off once you get it on hands or parts. And it's just not necessary for regular use. And it's definitely not good for bearings.
well.. my buddy uses this for his CZ...
http://amzn.to/1UQUZY4
makes the slide super slick and easy. maybe i'll try some on my crank and see.
- prendrefeu
- Contact:
goodboyr wrote:I would just use anti seize on titanium. Anything else is regular grease. I use finish line Teflon. Antiseize is tough stuff to clean off once you get it on hands or parts. And it's just not necessary for regular use. And it's definitely not good for bearings.
Bearing lube is different altogether! There are specific oils for bearings.
In terms of getting it off: easy wipe off... like this. http://www.amazon.com/Armor-All-10863-C ... 1462921343 or any equivalent.
Again the auto-industry is an easy go-to for things without the inflated cost of a bike brand.
And although it isn't necessary for basics, there's no harm in using it for basic situations either.
- prendrefeu
- Contact:
BB - personally I haven't had to re-grease bearings in a long, long time and that was with an old ISIS BB (just realized how that acronym has changed meaning over the past years)... The seals usually do the work just fine. Don't use anti-sieze grease here, but generally speaking a marine-grade bearing grease will work. The point is to have a thin film surrounding the bearings and keep dirt/water out (which is the point of the seals).
Mobil-1 grease works well, and again is affordable.
Ceramic bearings may have their own recommendations, I don't know... haven't had to touch bearings lube in a long while.
This is what I use on my bike:
Big bucket of cheap automotive grease that I bought 10 years ago. I think I've used almost 30% of it by now
Pedro's dry lube for the chain
Tacx carbon paste
Diesel fuel as degreaser
Car shampoo / wax
Cheap brushes and sponges
Kärcher
Tacx carbon paste
Car shampoo / wax
Kärcher
- MattSoutherden
Comma High Performance Bearing Grease
