D-Fly and Garmin 1000
superbikemike
by superbikemike
Recently my Garmin 1000 Di2 screen stopped showing the percent of battery charge. The screen now only shows a picture of a battery with a slash through it. Has anyone else experienced this and has been able to fix it?
Thanks
Mike
Current Rides
2021 Canyon Aeroad CFR Di2
2015 Specialized S-Works Venge Di2
2013 Trek Madone P1 7
2009 Cervelo P3
goodboyr
by goodboyr
Yes. The most recent Garmin firmware update enabled eps and e tap systems. It triggered this bug . You need to reselect that field and make sure you get the correct di2 battery field instead of the ones for etap and eps.
Choose "di2 battery" and not "gear battery".
superbikemike
by superbikemike
Thank you for your response it is definitely helpful. I did go into the tools section of my Garmin and reviewed my Di2 sensor profile although I can not find where to select Di2 over etap . My sensor profile shows Di2?
Sent from my iPad using Tapatalk HD
Thanks
Mike
Current Rides
2009 Cervelo P3
goodboyr
by goodboyr
It's in the actual data fields. Not the sensor profile. Just choose the particular data field by holding your finger on it and change the field accordingly.
goodboyr
by goodboyr
kungth wrote:choose di2 battery, not gear battery
Get that post count up............ :x :evil: :twisted:
by Nefarious86
Several of them in the last 24h..... Ban hammer time..
Using Tapatalk
goodboyr
by goodboyr
Chungmin, meet kungth..........you guys have a lot in common. Both should be banned!
