Hot weather ultralight Climbers jerseys: do they work?
mpulsiv
by mpulsiv
Fishnet sleeveless base layer does wonders. Craft is my favorite one, it soaks sweat and keeps my jersey dry. Best part - no athletic stink. http://www.competitivecyclist.com/craft ... F0MTAwMzE0
fignonsbarber
by fignonsbarber
mpulsiv wrote:Fishnet sleeveless base layer does wonders. Craft is my favorite one, it soaks sweat and keeps my jersey dry. Best part - no athletic stink. http://www.competitivecyclist.com/craft ... F0MTAwMzE0
I've always used Craft base layers for under 65 degrees. I'll try one of these.
BdaGhisallo
by BdaGhisallo
Do you find their effectiveness is greatly diminished in high humidity climates? I normally see humidity levels north of 80% and usually north of 90% for a good part of the summer. Base layers, of any kind, are stifling in those conditions. At those levels it is all about getting direct airflow over the skin, so it's a jersey only invariably with the zipper wide open.
efeballi
by efeballi
I rate Poc Climber's Jersey highly. Did two HC climbs last summer, did not soak with sweat.
Ditto on the fishnet baselayer.
Sent from my calculator using Tapatalk
SHUT UP LEGS
2015 Giant Propel Advanced
2015 Cannondale Supersix Evo
2013 KTM Strada mod. (totaled)
2011 Pinarello Dogma 60.1(loaner)
2011 Scott SUB 45(sold)
Politecnico di Milano Ingegneria Meccanica
mpulsiv
by mpulsiv
I wear fishnet Craft base layer all year long, whether it's freezing temperature or scorching heat. It's very effective. My jersey is pretty dry except for neck area, which is obvious. It's like new after years of usage, no athletic stink.
The sole purpose of a sleeveless fishnet base layer is to keep your jersey dry so it doesn't stick to your wet skin.
AE86Micah
by AE86Micah
I use Champ Sys air light jerseys while climbing, they make a huge difference going from the thicker material. I have never been sunburned through the jersey either.
