Lightest chain rings?
phourgenres
by phourgenres
I have three choices that are used. Stronglight, sworks, and sram red. Its going on a sram red exogram crankset. The sworks are only twenty bucks, the other two are fifty. I cant find any weights on sworks. Btw, id rather not comprise a ring that will wear quick if its only saving me 10-20g.
mpulsiv
by mpulsiv
Have you looked at cold forged Praxis chainrings? http://www.praxiscycles.com/road-cyclocross/
mulletmaster
by mulletmaster
Twenty bucks for chainrings!? Have I read that wrong?
Marin
by Marin
mulletmaster wrote:Twenty bucks for chainrings!? Have I read that wrong?
No but you didn't read the 1st sentence :D
Stronglight will be the lightest by far.
mulletmaster
by mulletmaster
Ah.... Indeed my mistake
964Cup
by 964Cup
Stronglight, but used chainrings can be a false economy. +1 for Praxis Works.
Tenlegs
by Tenlegs
Unfortunately Praxis Works are not compatible with the 4 arm sram red exogram crankset.
the sworks & stronglight might not fit either with the exogram "hidden 5th mount"
http://www.praxiscycles.com/compatibility/
AE86Micah
by AE86Micah
I use Praxis and love them. I've heard they will be coming out with a compatible set shortly.
junchen
by junchen
Wish there's praxis for campagnolo 5 arms...
Sent from my SM-G920I using Tapatalk
prendrefeu
by prendrefeu
Tenlegs wrote:Unfortunately Praxis Works are not compatible with the 4 arm sram red exogram crankset.
Sorry to counter you, but even Praxis themselves stated on this very site that they are compatible, while not "officially" compatible (because they would rather 'market' a 'special version' and make more money).
All you need to do is rotate the chainring 180°.
I would pull up the thread, but in that very thread a few WW users apparently didn't know how circles work ( :lol: )...and I don't want to embarrass.
pdlpsher1
by pdlpsher1
prendrefeu wrote:All you need to do is rotate the chainring 180°.
The only issue you would have doing this is that the chain 'catch pin' will be in the wrong position.
The replacement SRAM Red 22 large chainrings come with two chain 'catch pins' (offset by 180 degrees) so that the chainring is compatible with either a four-arm or the older five-arm design.
prendrefeu
by prendrefeu
First, this is Weight Weenies - ideally you'll have gotten rid of the catch pin. Like any WW you do have access to tools to remove it, right? Save some weight.
Second, you shouldn't need the catch pin if you've set up your FD proper.
Third, even if your catch pin is 180° so what? Does it hinder shifting or performance? Nope. Does it hurt humanity? Nope. Does it irk superficial, vanity-centric people who are spending their riding time looking at your bike instead of actually riding and enjoying the scenery? :noidea: Why are you riding with them?
Tenlegs
by Tenlegs
I'd never fit a chainring without a catchpin in the right place and I wouldn't recommend anyone else do it either,
as to removing it to save weight? that just sounds moronic, chains can and do come off, shit happens and always will
that's why every chainset/chainring has them and always will regardless of what you say or do with your bikes.
prendrefeu
by prendrefeu
Not all outer chainrings have them. They are not necessary. Helpful, yes, but not necessary for functionality of the chainring. Some chainrings provide them as 'options' (ie, removable).
And you're saying rotating a chainring 180° is moronic? Oh do tell us how circles work, this will be good. :popcorn:
There are more 'moronic' things that can be done to save weight, such as drilling holes into a fork, but filing down or removing a catchpin isn't one of them.
Yes, 'shit happens'... might as well stay at home then, sell the bike and spend the money on cable tv subscriptions! The world is too dangerous to take even the most calculated risk on something as minor as a catchpin. :roll:
Or hey, set up your FD properly. That'll help. :wink:
nickf
by nickf
Im running stronglight rings on my exogram crank without any issues. Front shifting is also great. Ill check when i get home but i don't think they have a catchpin. I dont remember having to grind one down but i could be wrong. But I wouldn't call it moronic for not having one.
